  • AtlasIED Atmosphere AZMP8-DW 8-Zone Processor w/1200W Amp, Dante, All-in-One Wall Mount Cabinet
AtlasIEDPart # 242-9604
Model: AZMP8-DW
The Atlas AZMP8-DW is a cutting-edge 1200-watt, 8-zone audio processor/amplifier designed to be the central hub of an Atmosphere audio control system. Featuring advanced DSP, innovative algorithms, and ample power to distribute across zones, it provides tailored audio solutions for a wide range of environments. With integrated Dante networked audio, the AZMP8-DW ensures seamless audio distribution across your Atmosphere network while being contained in a convenient, all-in-one case to eliminate the need for a traditional equipment rack.
  • No app needed; control Atmosphere simply through a web browser using the intuitive interface
  • 1200W that can be distributed across zones in 5W increments at user discretion to low Z, 70V, and 100V speakers
  • Inbuilt DSP offers learning ambient noise sensing, virtual wall controllers, Tilter Filter, auto-gain, GPIO, and much more
  • Accommodates up to 16 wall-mounted controllers/sensors across four accessory ports
  • Combine and group rooms for flexible configuration of different audio zones
  • Programmable message player and bell scheduler to play pre-recorded messages on a configurable schedule
  • Dante compatible to integrate seamlessly with other Dante-capable devices
Your Price: $7,123.99
MSRP: $7,498.99
Save $375.00 (5%)
Out of Stock
We'll send you an email when AtlasIED Atmosphere AZMP8-DW 8-Zone Processor w/1200W Amp, Dante, All-in-One Wall Mount Cabinet is back in stock or available for preorder.
Dropship Order Item
TheThe Atmosphere AZMP8-DW is a 1200-watt, 8-zone powered audio processor that serves as the core of an Atmosphere audio control system. Combining advanced DSP with innovative algorithms, it delivers customized audio solutions for various spaces. Its Dante networked audio capabilities enable seamless distribution to other Dante-compatible devices, while built-in features such as a message player, virtual wall controllers, learning ambient noise sensing, Tilter Filter, auto-gain, GPIO, bell scheduling, and room combining make it a powerful processing hub.
Forget about a traditional equipment rack and take advantage of the AZMP8-DW's unique shape. This locking cabinet included room for peripheral devices such as a network switch or music streamer.
Utilizing amplifier power-sharing technology, the AZMP8-DW maximizes efficiency by allocating available power based on demand, eliminating the need for excessive system design. Capable of delivering a total of 1200 watts, each output channel can be software-configured anywhere between 5 and 600 watts, providing precise power management tailored to specific installation requirements.
Designed for seamless integration, the AZMP8-DW is compatible with all seven Atmosphere wall plate accessories, supporting control, remote audio input, and ambient noise sensing. Up to 16 plug-and-play accessories can be connected across four accessory ports, with the option to add a zone paging station. Each port ensures reliable operation over distances of up to 1000 feet.
Programming is intuitive through an onboard web interface optimized for common use cases. Built on Progressive Web App technology, the control interface is device-agnostic, responsive, and user-friendly while maintaining design flexibility. In addition to Ethernet connectivity, built-in Wi-Fi enables tablets and other control devices to connect directly to the AZMP8-DW.
The Brooklyn 3 card used for Dante functionality supports up to 16x16 audio channels, though the AZMP8-DW is configured for 14x8 channels for Sources and Zones with onboard signal processing. Additional Dante outputs allow for seamless integration with other Dante-compatible devices, making it easy to route and distribute audio within the network.
Control modules available for RTI, Crestron, Extron, and AMX.
Request Atmosphere Firmware Update Notifications
What is the Atmosphere Platform?
An Audio Processing and Control System with Intelligent Design, Superior Performance Digital Signal Processors, Amplifiers, and Accessories
Experience freedom from Complexity to create your
Product FlyerSystem ExamplesFirmware Updates
Atmosphere Accessories
Ambient Noise Sensor
Zone, Source, and Volume Wall Controller
Volume Controller
Remote Bluetooth Audio Input
Remote XLR Input
RCA/3.5mm Audio Input
Wall Controller
Wall Controller with Bluetooth Audio
Virtual Wall Controller QR Code Holder
Zone Paging Station
Rack Mount Kits for Up to Five or Three Wall Controllers
Recommended Speakers
AS Series Surface Mount Loudspeakers
Isoflare In-Ceiling Loudspeakers
AimLine Digitally Steerable Surface Mount Column Array Loudspeaker
BrandAtlasIED
ModelAZMP8-DW
Part Number242-9604
UPC612079703159
Weight46
Power Output (RMS @ 70V)> 400W
Weight Range30 to 39 lbs.
