  • Tang Band W1-1070SI 1" Full-Range Speaker Module 4 Ohm 2" x 2"
BUYOUT Tang Band W1-1070SI 1" Full-Range Speaker Module 4 Ohm 2" x 2"
Factory BuyoutsPart # 299-574
Model: W1-1070SI
The Tang Band W1-1070SI is a compact full-range speaker module designed for projects that demand high performance in a tiny package. Built around the proven W1-1070SH 1" driver, this ready-to-use sealed module eliminates the need to design or build a micro-enclosure, making it easy to integrate into custom audio projects. Measuring just over 2" square and 1.25" deep, the W1-1070SI delivers smooth mids, crisp highs, and surprising low-end reach, making it perfect for desktop speakers, soundbars, embedded systems, and portable audio.
  • Compact sealed speaker module using Tang Band’s W1-1070SH 1" full-range driver
  • Ultra-small footprint: just over 2" × 2" with a depth of only 1.25"
  • Aluminum diaphragm with Santoprene surround for accurate, low-distortion response
  • Sealed design provides clean response down to 200 Hz
  • Neodymium motor and low inductance for extended treble clarity
  • Perfect for desktop, embedded systems, portable speakers, or custom DIY audio builds
Tang Band T1-2025SC Full-Range Speaker Module 1-5/8" x 1-1/2"
Price: $26.28Part # 264-939
See all items in Speaker Modules
BUYOUT $14.98
Save $35.01 (70%)
We'll send you an email when Tang Band W1-1070SI 1" Full-Range Speaker Module 4 Ohm 2" x 2" is back in stock or available for preorder.
Full-Range Performance in a Small Package
The Tang Band W1-1070SI brings big performance to small spaces in a self-contained, ready-to-use format. Using Tang Band’s highly regarded W1-1070SH 1" full-range driver, this sealed module delivers detailed mids and highs with a compact footprint just over 2" square and 1.25" deep. By providing its own enclosure, the W1-1070SI makes it easy to add high-quality sound to custom projects without the challenge of designing or building a tiny enclosure.
Driving the W1-1070SI is the aluminum-cone W1-1070SH full range driver, supported by a Santoprene surround and neodymium motor for smooth, controlled performance across its range. The rigid cone maintains pistonic motion at all output levels, while low inductance ensures clean, extended treble. With frequency response reaching from ~200 Hz up to 20 kHz, this tiny module covers the critical midrange and highs with surprising accuracy and output capability.
Thanks to its slim dimensions, the W1-1070SI can be mounted almost anywhere. It’s an excellent choice for desktop speaker arrays, slim soundbars, portable audio builds, or embedded systems where space is at a premium. Since the enclosure is already integrated, installation is as simple as mounting the module and wiring it in.
For designers and DIY builders who want full-range performance without the hassle of cabinet design, the Tang Band W1-1070SI is the perfect solution. Compact, versatile, and engineered around a proven Tang Band driver, this module makes it easy to bring clear, detailed sound to projects where size and simplicity matter most.
BrandFactory Buyouts
ModelW1-1070SI
Part Number299-574
UPC848864081380
Weight0.15
Nominal Diameter1"
Bolt Circle Diameter2.5
Power Handling (RMS)8 Watts
Power Handling (MAX)16 Watts
Impedance4Ω
Frequency Response200 - 20,000Hz
Sensitivity78dB 2.83V/1m
Resonant Frequency (Fs)400Hz
DC Resistance (Re)3.9Ω
Voice Coil Inductance (Le)0.05mH
Cone MaterialAluminum
Magnet MaterialNeodymium
Baffle Cutout Diameter2"
Depth1.25"
