  • Tang Band W3-2052SC 3" RBM Neodymium Subwoofer 4 Ohm
BUYOUT Tang Band W3-2052SC 3" RBM Neodymium Subwoofer 4 Ohm
Factory BuyoutsPart # 299-572
Model: W3-2052SC
The Tang Band W3‑2052SC is a potent 3″ subwoofer engineered for compact audio applications. Featuring a long-throw design (5 mm Xmax), neodymium motor, and a unique dual-surround, dual-layer diaphragm structure (no traditional spider), it delivers impressive bass output in a mini chassis. With exceptional linearity and low distortion traits this driver is ideal for multimedia systems, portable speakers, and micro‑home‑audio builds.
  • Long‑throw performance (Xmax = 5 mm) for extended bass output from a tiny driver
  • Poly diaphragm with Santoprene surround ensures a balanced and durable acoustic response
  • Dual‑surround design eliminates the need for a spider and enhances linear excursion
  • Suitable for small speaker arrays or compact subwoofer designs
Tang Band W3-1876S 3" Mini Subwoofer
Price: $64.99Part # 264-909
BUYOUT $29.98
Save $40.01 (57%)
We'll send you an email when Tang Band W3-2052SC 3" RBM Neodymium Subwoofer 4 Ohm is back in stock or available for preorder.
Compact Subwoofer, Big Punch
Don't let its size fool you—the Tang Band W3‑2052SC packs real low-end punch from a 3″ driver. With a substantial 5 mm linear excursion (Xmax), it produces deep and powerful bass in micro‑enclosures. Thanks to its polypropylene cone with Santoprene surround, this driver maintains controlled motion and long-term reliability.
Powering the W3‑2052SC is a precision-engineered neodymium magnet motor system with an overhung design that has been optimized to produce consistent magnetic flux across the large stroke. But what really sets it apart is the dual-surround, dual-diaphragm configuration—no conventional spider here. Instead, compliance is achieved through back-to-back surrounds, maintaining tight linearity even under stress.
Whether you’re building a compact 2‑way bookshelf speaker, a mini subwoofer, or upgrading older systems, the W3‑2052SC adapts beautifully. Optimized for linearity, this woofer produces clean, impactful lows in small systems where space matters most. It fits tight spaces with ease but performs like a driver twice its size.
BrandFactory Buyouts
ModelW3-2052SC
Part Number299-572
UPC848864081373
Weight0.55
Nominal Diameter3"
Bolt Circle Diameter3.8
Power Handling (RMS)15 Watts
Power Handling (MAX)30 Watts
Impedance4Ω
Frequency Response50 - 800Hz
Sensitivity78.3dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)59Hz
DC Resistance (Re)4.3Ω
Voice Coil Inductance (Le)1mH
Mechanical Q (Qms)6.48
Electromagnetic Q (Qes)0.53
Total Q (Qts)0.49
Compliance Equivalent Volume (Vas)0.021ft³
Mechanical Compliance of Suspension (Cms)0.5mm/N
BL Product (BL)6.6T·m
Diaphragm Mass Inc. Airload (Mms)14.8g
Surface Area of Cone (Sd)28.8cm²
Cone MaterialPoly Composite
Magnet MaterialNeodymium
Overall Outside Diameter3.25"
Baffle Cutout Diameter3"
Depth1.75"
Vented Volume0.05ft³
Vented F344Hz
