  • Pyle PLPW6D Power 6-1/2" 600 Watt DVC Subwoofer
Pyle AudioPart # 267-7450
Model: PLPW6D
The 6" Pyle Power Series subwoofer utilizes a small-enclosure and adds the extra punch to your low-end. With its reinforced polymer basket for durability and the wide, non-fatiguing foam surround, this subwoofer is ready to be put to use.
  • Bumped and vented motor construction reduces heat build-up and extends the life
  • 1.5" four-layer high-temperature dual voice coil with 30 oz. magnet handles 300 watts of continuous booming bass
  • Stitched surround for maximum durability
  • Naturally damped treated paper cone for natural response
Your Price: $24.28
Save $22.71 (48%)
We'll send you an email when Pyle PLPW6D Power 6-1/2" 600 Watt DVC Subwoofer is back in stock or available for preorder.
The PLPW6D 6" booming 600 watt subwoofer's design attracts those who love bass. This subwoofer will make your music growl in your vehicle or at home, in any type of enclosure: sealed, vented, or open-air. The black reinforced polymer basket and non-pressed paper cone look sleek - and thanks to a massive ferrite magnet, 1.5" four-layer dual voice coil, and specially treated foam surround, it sounds great too.
BrandPyle Audio
ModelPLPW6D
Part Number267-7450
UPC068889019490
Weight2.8
Nominal Diameter6"
Power Handling (RMS)300 Watts
Power Handling (MAX)600 Watts
Impedance8Ω
Frequency Response70 to 6,000Hz
Sensitivity89dB 2.83V/1m
Voice Coil Diameter1.5"
Magnet Weight30oz.
Resonant Frequency (Fs)52.2Hz
DC Resistance (Re)6.8Ω
Mechanical Q (Qms)3.63
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)0.54ft³
Surface Area of Cone (Sd)131cm²
Cone MaterialPaper
Surround MaterialFoam
Overall Outside Diameter6.5"
Baffle Cutout Diameter5.6"
Depth3"
Sealed Volume0.25ft³
Sealed F3106.3Hz
Vented Volume0.6ft³
Vented F351.1Hz
