  • Pyle PLPW15D Power 15" 2000 Watt DVC Subwoofer
Pyle AudioPart # 267-7448
Model: PLPW15D
The PLPW15D, a 15" 2000 watt subwoofer is designed with bassheads in mind. The black reinforced polymer basket and non-press paper cone look sleek, and all you need to do is connect to your amplifier using the spring loaded, push-down speaker terminals and feel the Pyle power.
  • Spring loaded push down speaker terminals
  • Specially treated foam surround for increased longevity
  • Well damped non-pressed paper cone
Your Price: $82.08
Save $21.91 (21%)
We'll send you an email when Pyle PLPW15D Power 15" 2000 Watt DVC Subwoofer is back in stock or available for preorder.
The PLPW15D is a 15-Inch booming 2000 watt subwoofer designed with the bass lover in mind. This subwoofer will reproduce low frequencies in your vehicle or at home, in any type of enclosure: sealed, vented, or open-air. The black reinforced polymer basket and non-pressed paper cone look sleek - and thanks to a 95 oz. magnet, 2.5-Inch four-layer dual voice coil, and specially treated foam surround, it sounds great too. Simply connect to your amplifier using the spring loaded, push-down speaker terminals and feel the Pyle Power.
BrandPyle Audio
ModelPLPW15D
Part Number267-7448
UPC068889019537
Weight11.35
Nominal Diameter15"
Impedance8Ω
Frequency Response40 to 1,500Hz
Sensitivity90dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)29.02Hz
DC Resistance (Re)6.8Ω
Mechanical Q (Qms)3.94
Electromagnetic Q (Qes)0.52
Total Q (Qts)0.46
Compliance Equivalent Volume (Vas)6.91ft³
Maximum Linear Excursion (Xmax)8mm
Surface Area of Cone (Sd)0.08cm²
Cone MaterialPaper
Surround MaterialFoam
Overall Outside Diameter15.3"
Depth6.3"
Sealed Volume2.5ft³
Sealed F351.7Hz
Vented Volume4.25ft³
Vented F334.6Hz
