  • PRV Audio 69MR500CF-NDY-4 6"x9" Neodymium Midrange Speaker Pair
PRV AudioPart # 294-3504
Model: 69MR500CF-NDY-4
The PRV Audio 69MR500CF‑NDY‑4 is a 6×9″ neodymium midrange speaker with a carbon fiber cone built for outdoor pro‑audio use. Engineered for water‑resistant durability, it delivers precise, low‑distortion sound in compact spaces. Ideal for boats, UTVs, motorcycles, and other powersports applications.
  • Water‑resistant build for reliable outdoor performance
  • Carbon fiber cone reduces weight and unwanted resonances
  • Neodymium magnet for high output in a lightweight package
  • 96 dB sensitivity offers efficient, dynamic midrange sound
  • High‑temp 2″ voice coil ensures durability under heavy use
  • Ventilated design keeps cool under power peaks
  • Sold in pairs with grilles and mounting hardware for easy install
Your Price: $299.91
Save $74.98 (20%)
We'll send you an email when PRV Audio 69MR500CF-NDY-4 6"x9" Neodymium Midrange Speaker Pair is back in stock or available for preorder.
Estimated back in stock 11/5/2026
The MR500CF-NDY series was engineered for powersports applications, featuring a water-resistant design that delivers reliable performance while withstanding the challenges of outdoor environments.
Perfect for enhancing your audio system on boats, UTVs, ATVs, or motorcycles, this midrange speaker sets a new benchmark for vocal clarity in outdoor use. Built with premium components including a carbon fiber cone, high-temperature voice coil, and a powerful neodymium magnet, it delivers natural sound with impressively low distortion.
  • Water resistant with authentic pro audio midrange performance
  • Damped carbon fiber cone reduces moving mass and controls unwanted resonance
  • Low inductance design with extended frequency response
  • High-strength neodymium motor includes distortion-reducing components
  • Quick transient response with minimal coloration and impactful midbass
  • Sold in matched pairs with grille and mounting screws included
This midrange features a suspension system with a single-layer spider and premium stitched lead wires connected to a copper-clad aluminum voice coil, ensuring high efficiency and strong power handling. The voice coil is immersed in a powerful magnetic field generated by high-power neodymium radial slugs, optimizing performance.
You can count on excellent off-axis dispersion and fast transient response, delivering a wide sound stage and realistic, detailed sound from this water-resistant driver.
Built for loud, clear vocal performance in tight and compact installations, PRV Audio’s 69MR500CF-NDY-4 neodymium midrange delivers 96 dB sensitivity (2.83V/1m) while weighing just 4.16 pounds. With a 4-ohm impedance, it's engineered specifically for high-output motorsports audio systems.
Its bumped back plate, vented magnet structure, and vented pole piece work together with the high-temperature voice coil to enable strong power handling and durability. These features help the driver withstand intense transient power spikes, ensuring reliable performance in demanding conditions.
  • Nominal Diameter: 6″x9″ (152 x 228 mm)
  • Nominal impedance: 4 Ohm
  • Nominal Power Handling: 250 Watts
  • Continuous Program Power (RMS): 500 Watts
  • Max Peak Power: 1000 Watts
  • Sensitivity 2.00V at 1m: 96 dB
  • Recommended High Pass Crossover**: 110 Hz*
    **For Full Power Handling         *12db Per Octave Crossover
  • Frequency Response: 100 – 13,000 Hz
  • Voice Coil Diameter: 2″ (50.8 mm)
  • Voice Coil Wire: CCAW
  • Former Material: Kapton
  • Frame Material: Stamped Steel
  • Overall Diameter: 6.44”x9.29″ (163.5×236 mm)
  • Front Mount Baffle Cutout: 5.87”x8.62 (149×219 mm)
  • Mounting Depth: 3.39” (86 mm)
  • Overall Depth: 3.74” (95 mm)
  • Net Weight: 3.86 Lbs (1.75 kg)
BrandPRV Audio
Model69MR500CF-NDY-4
Part Number294-3504
UPC810075520880
Unit of MeasurePairs
Weight10
Power Handling (RMS)500 Watts
Impedance4Ω
Frequency Response100 to 13,000Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)91Hz
DC Resistance (Re)3.4Ω
Voice Coil Inductance (Le)0.05mH
Mechanical Q (Qms)15.81
Electromagnetic Q (Qes)0.36
Total Q (Qts)0.35
Compliance Equivalent Volume (Vas)0.316ft³
Mechanical Compliance of Suspension (Cms)0.136mm/N
BL Product (BL)10.92T·m
Diaphragm Mass Inc. Airload (Mms)22.34g
Maximum Linear Excursion (Xmax)3.25mm
Surface Area of Cone (Sd)216cm²
Cone MaterialCarbon Fiber
Voice Coil Wire MaterialCCA
Magnet MaterialNeodymium
Baffle Cutout Diameter5.87 x 8.62"
Depth3.39"
Sealed Volume0.06ft³
Sealed F3220Hz
Vented Volume0.157ft³
Vented F3124.7Hz
