CLEARANCE Neutrik NE8FBH-C5-LED1-S etherCON B Series Shielded Panel Mount Connector Horizontal PCB with Light Pipes for SMD-LEDs
Horizontal PCB mount RJ45 receptacle, CAT5e, shielded, two light pipes for SMD-LEDs, B-Series cutout with latch lock, max. panel thickness 3 mm.
The etherCON Series is a ruggedized and lockable RJ45 connector system, optimized for pro audio, video and lightning network applications. The chassis connectors are shaped to fit into standardized panels out of the entertainment industry. The B-Series offers a space saving design and a rugged metal front plate.
- Accommodates rugged etherCON NE8MC* or any standard RJ45 plug
- Approved latch lock system
- Ground panel connection
- PoE type 4 class 8 (100W) acc. IEEE 802.3bt
- CAT5e according to ISO/IEC 11801 and TIA/EIA 568A/B
- Does not intermate with CAT6 cable connector NE8MC6-MO and NKE6S* cables
We'll send you an email when Neutrik NE8FBH-C5-LED1-S etherCON B Series Shielded Panel Mount Connector Horizontal PCB with Light Pipes for SMD-LEDs is back in stock or available for preorder.
