  • Stahl Tools HH4 Helping Hand with 4 Flexible Arms, Tip Cleaner, Rosin, and Solder Roll Holder
Stahl ToolsPart # 374-706
Model: HH4
The Stahl Tools HH4 multi-purpose tool offers an excellent all-around solution for working on small PCBs, components, connectors, and other soldering jobs. The four flexible plastic helping hands make it unique from other soldering aids.
  • Sturdy metal base, with rubber sleeves, keeps the stand from sliding or tipping over
  • Plastic flexible arms enable you to adjust them while soldering
  • Includes four plastic flexible arms with alligator clips, soldering wire spool holder, sponge, rosin, as well as cleaning ball, to help with soldering
  • Unique all-in-one design saves space on your workbench
Your Price: $19.98
MSRP: $29.99
Save $10.01 (33%)
258 In Stock
We'll send you an email when Stahl Tools HH4 Helping Hand with 4 Flexible Arms, Tip Cleaner, Rosin, and Solder Roll Holder is back in stock or available for preorder.
Order in the next 2 hr 3 min to ship today. Details
This complete multi-purpose soldering stand saves space and makes any small soldering job a simple task. Two alligator clips steady your board/connector while the other two alligator clips are free to hold wire, electrical components, or even solder for precision work. It's okay to grab the plastic arms to adjust your work since they won’t get hot. The soldering stand keeps your helping hands, tip cleaner, sponge, flux, and solder spool all together to save space on your workbench.
  • Plastic flexible arms: 8-1/2" long with 1-1/2" clip and 6" is flexible
  • Sponge size: 30 mm x 50 mm
  • Rosin: 10g
  • Base size: 7-1/2" L x 6-3/4" W (190 x 170 mm)
  • Unit weight: 1.8 lbs.
BrandStahl Tools
ModelHH4
Part Number374-706
UPC848864069975
Weight1.8
