  • Stahl Tools RM 4.25" x 6.75" Magnifier Lens with 80 LED Workbench Light and 20" Arm
CLEARANCE Stahl Tools RM 4.25" x 6.75" Magnifier Lens with 80 LED Workbench Light and 20" Arm
Stahl ToolsPart # 374-704
Model: RM
Light up your work and keep a close eye on it with Stahl Tools RM 4.25" x 6.75" white workbench LED magnifier. This LED magnifier lamp is the perfect solution for technicians, crafters, and anyone else who needs a better look at fine detail.
  • Lower power consumption vs. incandescent saves energy without sacrificing brightness
  • LEDs mean long lifetime and reduced risk of breakage
  • Unique rectangle lens for better viewing when working on PC boards
  • 3D-diopter lens for close up work
  • 20" arm folds down to the perfect viewing angle
  • 2-3/4" C-clamp for mounting versatility
We'll send you an email when Stahl Tools RM 4.25" x 6.75" Magnifier Lens with 80 LED Workbench Light and 20" Arm is back in stock or available for preorder.
This 120 VAC desktop LED magnifier work lamp uses 80 high-output, long lasting, low power consumption LEDs to illuminate whatever you are working on. The 1.75x magnification lens lets you see a level of detail that would be impossible with the naked eye. A unique 4.25" x 6.75" rectangle lens enables technicians to see an entire small PC board without blurring the edges. The 20" arm mounts to your desk with a 2-3/4" C-clamp and folds down to bring the 80 LEDs closer to your work, and makes additional viewing angles possible. A hinged lid stays open until you shut it to keep the lens clean and the 80 LEDs then turn into a nice desk lamp. We think this workbench magnifier is so handy that no household should be without one!
BrandStahl Tools
ModelRM
Part Number374-704
UPC848864049731
Weight5.25
