  • 50 ft. Talent Cat6A SF/UTP Shielded Grounded Ethercon Cable with Rugged Neutrik Housing
Talent Sound & LightingPart # 240-9405
Model: NECG-50
Connect your XLR extenders or DSP mixer with other digital components with this Talent CAT6A shielded Ethercon cable. Uses Neutrik etherCON metal shells and grounded to pass on phantom power.
  • Durable CAT6A 8mm O.D. cable with a dual rubber jacket that stands up to stage use
  • Neutrik metal shells for dependable tight fit
  • Shielded to prevent outside interference
  • Grounded to pass through phantom power when using with XLR extenders
  • Neutrik etherCON metal shell removes easily when plugging into a standard RJ-45 jack
  • Removable ground option for equipment that doesn't need it
  • Gold plated terminals for quality signal transfer and long lasting connection
Your Price: $74.98
Save $70.01 (48%)
64 In Stock
We'll send you an email when 50 ft. Talent Cat6A SF/UTP Shielded Grounded Ethercon Cable with Rugged Neutrik Housing is back in stock or available for preorder.
Order in the next 13 hr 29 min to ship today. Details
Take this Talent Ethercon CAT6A cable on the road to multiple venues to hook up your digital or networking components. The thick rubber outer jacket stands up to multiple installs when setting up on various stages. The metal Neutrik etherCON shell snaps into etherCON jacks with a secure fit even when stepped on or abused. Easily remove the Neutrik etherCON shell to hook up to standard RJ-45 jacks and enjoy the speed of CAT6A performance.
Talent Ethercon cables work great with XLR extenders. This combination saves time and space when setting up multiple microphones in one area. It helps eliminate large snakes or multiple microphone cables stretched out all over the stage. The ground wire in the Talent Ethercon cables enables the XLR extenders to pass ground to phantom powered microphones.
For equipment that doesn't need a ground, or where a ground wire could cause issues, this Talent Ethercon cable is still the solution. The ground wire has the ability to be lifted from the shielded RJ-45 connector inside the etherCON shell. After removing the etherCON shell you'll see that the ground wire is crimped under the metal strain relief of the RJ-45 connector. Remove the ground wire from under the strain relief and cut it off or tape it up if you want to reinstall it later. The Talent NECG series Ethercon cables meet the need for long run or short runs, and will withstand the demand of the professional stage hands that need a dependable Ethercon/networking cable.
Specifications: • Cable outer diameter: 0.315" (8mm) • Dual jacket thickness: Black 0.031" (0.8mm), Gray 0.031" (8mm) • Dual shield: Aluminum foil and OFC copper braid • Cable rating: CAT6A • RJ-45 connector: Shielded with external ground.
BrandTalent Sound & Lighting
ModelNECG-50
Part Number240-9405
UPC848864067827
Weight2.6
Cable Length50feet
Jacket ColorBlack
