30 ft. Talent Cat6A SF/UTP Shielded Grounded Ethercon Cable with Rugged Neutrik Housing
- Durable CAT6A 8mm O.D. cable with a dual rubber jacket that stands up to stage use
- Neutrik metal shells for dependable tight fit
- Double shielded to prevent outside interference
- Grounded to pass through phantom power when using with XLR extenders
- Neutrik etherCON metal shell removes easily when plugging into a standard RJ-45 jack
- Removable ground option for equipment that doesn't need it
- Gold plated terminals for quality signal transfer and long lasting connection
42In Stock
We'll send you an email when 30 ft. Talent Cat6A SF/UTP Shielded Grounded Ethercon Cable with Rugged Neutrik Housing is back in stock or available for preorder.
