  • GRS 46AS-4 4" x 6" Dual Cone Replacement Car Speaker 4 Ohm
GRSPart # 292-457
Model: 46AS-4
GRS' 4" x 6" oval automotive speaker is a perfect choice for replacing blown, aging, or damaged original-equipment speakers in your car or truck. Features a dual cone design for durability and wide range audio reproduction.
  • Common 4" x 6" size drops into many OEM speaker locations
  • Poly cone helps keep unwanted cone resonance under control
  • Multiple mounting options fit a wider range of factory locations
  • Aluminum voice coil former improves heat dissipation for better power handling
  • Mylar whizzer cone extends high-frequency output
  • Sold individually
Your Price: $7.99
MSRP: $10.99
Save $3.00 (27%)
We'll send you an email when GRS 46AS-4 4" x 6" Dual Cone Replacement Car Speaker 4 Ohm is back in stock or available for preorder.
Order in the next 2 hr 58 min to ship today. Details
GRS AS-series car replacement speakers are economical drop-in replacements for blown, damaged, or dry-rotted speakers used in many vehicle models. These affordable automotive replacement speakers are available in sizes from 3-1/2" to 6" x 9", to fit virtually any existing speaker location in your vehicle. Replace your damaged or aging automotive speakers, and restore the sound of your vehicle!
The 4" x 6" frame size is a common size found in GM and other makes of vehicle, normally as front door speakers. Check your vehicle’s manual or other references to verify compatibility. Sold individually.
Specifications: • Power handling: 25 watts RMS/50 watts max •Impedance: 4 ohms • Frequency Response: 85-6,500 Hz • SPL: 88.4 dB@2.84V/1m • Mounting Depth: 1.88".
BrandGRS
Model46AS-4
Part Number292-457
UPC848864012179
Weight0.95
Speaker Size4"
Speaker TypeDual-Cone
Power Handling (RMS)25 Watts
