  • GRS 5AS-4 5-1/4" Car Replacement Speaker 4 Ohm
GRSPart # 292-455
Model: 5AS-4
GRS' 5-1/4" round automotive speaker is a perfect choice for replacing blown, aging, or damaged original-equipment speakers in your car or truck. Features a dual cone design for durability and wide range audio reproduction.
  • Common 5-1/4" size drops into many OEM speaker locations
  • Poly cone helps keep unwanted cone resonance under control
  • Extremely low moving mass to keep efficiency high
  • Aluminum voice coil former improves heat dissipation for better power handling
  • Mylar whizzer cone extends high-frequency output
  • Sold individually
Your Price: $8.99
MSRP: $11.99
Save $3.00 (25%)
We'll send you an email when GRS 5AS-4 5-1/4" Car Replacement Speaker 4 Ohm is back in stock or available for preorder.
GRS AS-series car replacement speakers are economical drop-in replacements for blown, damaged, or dry-rotted speakers used in many vehicle models. These affordable automotive replacement speakers are available in sizes from 3-1/2" to 6" x 9", to fit virtually any existing speaker location in your vehicle. Replace your damaged or aging automotive speakers, and restore the sound of your vehicle!
5-1/4" round speakers are normally found in the front doors of many vehicles. Check your vehicle's manual or other references to verify compatibility. Grill not included. Sold individually.
Specifications: • Power handling: 30 watts RMS/60 watts max • Impedance: 4 ohms • Frequency response: 75-7,000 Hz • SPL: 88.4 dB@2.83V/1m • Mounting depth: 2.25" • Bolt spacing: 5.5" CTC.
BrandGRS
Model5AS-4
Part Number292-455
UPC848864012155
Weight1
Speaker Size5.25"
Speaker TypeDual-Cone
Power Handling (RMS)30 Watts
