FaitalPRO 18HW1070 18" Professional Subwoofer 8 Ohm
The FaitalPRO 18HW1070 is an 18″ low‑frequency transducer built for professional subwoofer systems where deep bass, strong output and reliability are required. With its large motor structure and high excursion capability it’s designed to deliver serious bass performance.
- 1,600 W AES power handling for sustained high output
- 4″ copper voice coil on a fiberglass former supports high thermal loads
- Frequency range from 30 Hz to 1,500 Hz gives wide bass coverage
- ±13 mm Xmax and 30 mm peak‑to‑peak excursion for controlled movement
- Large ferrite ring magnet with flux density of 1.1 T for motor strength
- Aluminum basket with triple‑roll treated polycotton surround for durability
- Made in Italy
We'll send you an email when FaitalPRO 18HW1070 18" Professional Subwoofer 8 Ohm is back in stock or available for preorder.
