  • FaitalPRO 18HW1070 18" Professional Subwoofer 4 Ohm
NEW FaitalPRO 18HW1070 18" Professional Subwoofer 4 Ohm
FaitalPROPart # 294-1068
Model: 18HW1070
The FaitalPRO 18HW1070 is an 18″ low‑frequency transducer built for professional subwoofer systems where deep bass, strong output and reliability are required. With its large motor structure and high excursion capability it’s designed to deliver serious bass performance.
  • 1,600 W AES power handling for sustained high output
  • 4″ copper voice coil on a fiberglass former supports high thermal loads
  • Frequency range from 30 Hz to 1,500 Hz gives wide bass coverage
  • ±13 mm Xmax and 30 mm peak‑to‑peak excursion for controlled movement
  • Large ferrite ring magnet with flux density of 1.1 T for motor strength
  • Aluminum basket with triple‑roll treated polycotton surround for durability
  • Made in Italy
FaitalPRO 18HP1010 18" Professional Subwoofer 4 Ohm
Price: $473.00Part # 294-1065
NEW $728.00
We'll send you an email when FaitalPRO 18HW1070 18" Professional Subwoofer 4 Ohm is back in stock or available for preorder.
The 18HW1070 brings together high efficiency and rugged design to ensure trustworthy performance in demanding environments. Its 1,600 W AES rating and 96 dB sensitivity allow for strong output without oversizing the amplifier. A 4″ copper voice coil on a fiberglass former provides excellent heat resilience, while the wide 30–1,500 Hz bandwidth covers everything from deep sub‑bass up into the lower mid‑range. With ±13 mm Xmax and 30 mm peak‑to‑peak excursion, the driver handles large dynamic swings while staying controlled. The ferrite ring magnet with 1.1 T flux density ensures excellent motor performance, and the aluminum basket and triple‑roll treated surround enhance durability and excursion stability in long‑term deployment.
BrandFaitalPRO
Model18HW1070
Part Number294-1068
UPC848864081717
Weight33.95
Nominal Diameter18"
Bolt Circle Diameter17.32
Power Handling (RMS)1600 Watts
Power Handling (MAX)3200 Watts
Frequency Response30 to 1500Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)32Hz
DC Resistance (Re)
Voice Coil Inductance (Le)1.26mH
Mechanical Q (Qms)10.6
Electromagnetic Q (Qes)0.34
Total Q (Qts)0.33
Compliance Equivalent Volume (Vas)6.76ft³
Mechanical Compliance of Suspension (Cms)0.09mm/N
BL Product (BL)21.6T·m
Diaphragm Mass Inc. Airload (Mms)265g
Maximum Linear Excursion (Xmax)13mm
Surface Area of Cone (Sd)1212cm²
Voice Coil FormerFiberglass
Overall Outside Diameter18.11"
Baffle Cutout Diameter16.61"
Depth8.78"
Sealed Volume22.71ft³
Sealed F389.45Hz
Vented Volume79.11ft³
Vented F346.42Hz
