  • FaitalPRO 18HP1010 18" Professional Subwoofer 8 Ohm
NEW FaitalPRO 18HP1010 18" Professional Subwoofer 8 Ohm
FaitalPROPart # 294-1066
Model: 18HP1010
The FaitalPRO 18HP1010 is a high-performance 18″ woofer designed for demanding sound reinforcement systems. It delivers powerful, punchy bass with impressive output and clarity, making it ideal for large venues and touring rigs. This driver combines high power handling with great sensitivity to deliver serious low-end performance.
  • 1000 W AES power handling for sustained high output
  • 4″ copper voice coil on glass‑fiber former for thermal durability
  • Frequency range 35–2000 Hz affords deep extension and low‑mid support
  • ±9.75 mm Xmax and 21.9 mm peak‑to‑peak excursion for large‑air movement
  • Ferrite ring magnet (1.05 T flux) and aluminum basket for motor strength
  • Triple‑roll treated polycotton surround supports high excursion life
  • Made in Italy
FaitalPRO 18HW1070 18" Professional Subwoofer 8 Ohm
Price: $764.00Part # 294-1069
NEW $497.00
We'll send you an email when FaitalPRO 18HP1010 18" Professional Subwoofer 8 Ohm is back in stock or available for preorder.
The 18HP1010 brings serious bass capability to full‑range and subwoofer systems with its 1000 W AES rating paired with a high 98 dB sensitivity. The 4″ copper voice coil mounted on a glass‑fiber former is designed for extended duty cycles and heavy excursion without thermal breakdown. With a frequency range starting at 35 Hz and extending to 2000 Hz, this driver covers the deep‑bass domain as well as the lower mid‑frequencies, making it versatile in both sub and low‑mid applications. The generous ±9.75 mm Xmax and 21.9 mm damage‑limit excursion give it the mechanical headroom to handle dynamic material cleanly. The ferrite ring magnet structure with 1.05 T flux and a rigid aluminum basket offer high motor stability and low distortion under load. The triple‑roll treated polycotton surround and overall build quality ensure durability in installation or touring systems. In short, the 18HP1010 is a professional‑grade driver built to deliver strong, reliable bass performance in demanding environments.
BrandFaitalPRO
Model18HP1010
Part Number294-1066
UPC848864081700
Weight23
Nominal Diameter18"
Bolt Circle Diameter17.32
Frequency Response35 to 2000Hz
Sensitivity98dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)35Hz
DC Resistance (Re)5.3Ω
Voice Coil Inductance (Le)1.8mH
Mechanical Q (Qms)7.8
Electromagnetic Q (Qes)0.42
Total Q (Qts)0.4
Compliance Equivalent Volume (Vas)8.48ft³
Mechanical Compliance of Suspension (Cms)0.12mm/N
BL Product (BL)22T·m
Diaphragm Mass Inc. Airload (Mms)175.2g
Maximum Linear Excursion (Xmax)9.75mm
Surface Area of Cone (Sd)1207cm²
Voice Coil FormerFiberglass
Overall Outside Diameter18.11"
Baffle Cutout Diameter16.57"
Depth8.01"
Sealed Volume23.58ft³
Sealed F380.93Hz
Vented Volume99.51ft³
Vented F337.44Hz
