  • Dayton Audio RS100P-4 4" Reference Paper Woofer 4 Ohm
Dayton AudioPart # 295-369
Model: RS100P-4
Dayton Audio Reference Series paper cone drivers combine class-leading low distortion performance with super smooth frequency response due to the use of a proprietary cone blend.
  • Three-part paper composite diaphragm featuring paper, Kevlar, and glass fibers
  • Similar cosmetics and design features as original Reference Series with low-distortion
  • Perfect for use a woofer, midwoofer, or dedicated midrange driver
Your Price: $35.98
Save $13.01 (27%)
We'll send you an email when Dayton Audio RS100P-4 4" Reference Paper Woofer 4 Ohm is back in stock or available for preorder.
The performance of the original groundbreaking Reference Series from Dayton Audio, now available with a paper cone! The Reference Series Paper drivers use a proprietary paper cone formulation combining natural paper pulp and synthetic Kevlar® and glass fibers to create an advanced non-woven fiber composite that delivers the perfect combination of excellent detail and smooth, natural sonic character, plus a distinctive, classy look.
ModelRS100P-4
Part Number295-369
UPC848791001413
Weight1.3
Nominal Diameter4"
Bolt Circle Diameter3.54
Power Handling (RMS)30 Watts
Power Handling (MAX)45 Watts
Frequency Response85 to 13,500Hz
Sensitivity88.5dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)84.8Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.26mH
Mechanical Q (Qms)2.67
Electromagnetic Q (Qes)0.67
Total Q (Qts)0.54
Compliance Equivalent Volume (Vas)0.07ft³
Mechanical Compliance of Suspension (Cms)0.95mm/N
BL Product (BL)2.95T·m
Diaphragm Mass Inc. Airload (Mms)3.7g
Surface Area of Cone (Sd)36.3cm²
Cone MaterialPaper / Kevlar
Overall Outside Diameter3.86"
Baffle Cutout Diameter3.04"
Depth2"
# Mounting Holes6
Sealed Volume0.04ft³
Sealed F3144Hz
Vented Volume0.15ft³
Vented F359Hz
