  • Dayton Audio DSA315-8 12" Designer Series Aluminum Cone Woofer
Dayton AudioPart # 295-534
Model: DSA315-8
Great looks, high efficiency, and clean bass are notable attributes of Dayton Audio's Designer Series DSA315-8 12" woofer.
  • Cosmetic frame with low profile lip, designed for front mounting—no countersinking required!
  • Low distortion motor system with copper shorting ring
  • Black anodized aluminum cone, half roll rubber surround for durability and accurate reproduction
  • Smooth frequency response and linear roll-off simplify filter design
  • Vented pole piece for minimized power compression and maximized reliability
  • Retains the same "family look" as the popular Dayton Audio DVC Series subwoofers and passive radiators
  • Generous Xmax capability encourages use of moderate bass boost to tailor the response
Your Price: $128.98
MSRP: $167.99
Save $39.01 (23%)
Only 13 In Stock More due on 6/5/2026
We'll send you an email when Dayton Audio DSA315-8 12" Designer Series Aluminum Cone Woofer is back in stock or available for preorder.
Order in the next 4 hr 46 min to ship today. Details
The Designer Series by Dayton Audio was developed specifically with the speaker designer in mind. It is an affordable, attractive line of drivers that puts performance first. Careful engineering ensures that each speaker in the series is capable of handling full rated power at the lowest possible frequencies — without exceeding Xmax.
These speakers combine useful performance parameters with elegant style. Carefully optimized to provide superb audio reproduction when incorporated into a wide variety of enclosures and alignments, the Designer Series transducers put a beautiful face on audiophile excellence.
ModelDSA315-8
Part Number295-534
UPC848791002441
Weight13.75
Nominal Diameter12"
Power Handling (RMS)120 Watts
Power Handling (MAX)240 Watts
Frequency Response24 to 2,000Hz
Sensitivity90.3dB 2.83V/1m
Voice Coil Diameter1.95"
Resonant Frequency (Fs)24.23Hz
DC Resistance (Re)
Voice Coil Inductance (Le)1.11mH
Mechanical Q (Qms)1.89
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.33
Compliance Equivalent Volume (Vas)5.19ft³
Mechanical Compliance of Suspension (Cms)0.38mm/N
BL Product (BL)16.1T·m
Diaphragm Mass Inc. Airload (Mms)113.1g
Maximum Linear Excursion (Xmax)5.5mm
Surface Area of Cone (Sd)506.7cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter12.36"
Baffle Cutout Diameter10.71"
Depth5.12"
# Mounting Holes5
Sealed Volume1ft³
Sealed F358Hz
Vented Volume2.1ft³
Vented F336Hz
