  • Dayton Audio DSA315-PR 12" Designer Series Aluminum Cone Passive Radiator
Dayton AudioPart # 295-554
Model: DSA315-PR
The Dayton Audio Designer Series passive radiators are excellent general-purpose passives suitable for replacement or for new construction. Built to be a perfect match for the Designer Series drivers, these passive radiators feature the same steel frame, rubber surround, and anodized aluminum cone making them visually identical.
  • Cosmetic frame edge looks great even when surface mounted
  • Allows tuning small enclosures lower than using conventional ports
  • Rear mounted screw allows easy mass adjustment for custom tuning
  • Perfect match for Dayton Audio's aluminum cone Designer Series drivers
Your Price: $65.98
MSRP: $85.99
Save $20.01 (23%)
Only 1 In Stock More due on 4/17/2026
We'll send you an email when Dayton Audio DSA315-PR 12" Designer Series Aluminum Cone Passive Radiator is back in stock or available for preorder.
Order in the next 5 hr 5 min to ship today. Details
The Dayton Audio Designer Series passive radiators are excellent general-purpose passives suitable for replacement or for new construction. A built-in mass disc offers a good starting point for most designs, and a convenient M5 threaded hole (screw included) allows different types of weights to be added if desired. Cosmetically and mechanically, these passives match Dayton Audio's Designer Series drives, with a black anodized aluminum cone and medium-roll rubber surround for clean excursion and long life. The possibilities with these passives are endless, from large tower designs to compact subwoofer systems.
Specifications: • Fs: 17.5 Hz • Vas: 6.74 ft³ • Qms: 6.23 • Cms: 0.58 mm/N • Rms: 2.5 kg/s • Mms: 142.6 g • Sd: 480 sq. cm. • Xmax: 13 mm • Dimensions: Overall diameter: 12.36", Cutout diameter: 10.71", Depth: 3.50".
Note: Adding mass to the passive radiator will decrease Fs and increase Qms.
Tip: As a general rule, the passive radiator(s) should have at least double the displacement of air (Vd) as the active woofer(s)/subwoofer(s) in the system.
To calculate Vd: Sd x Xmax = Vd
ModelDSA315-PR
Part Number295-554
UPC848791005084
Weight2.65
Nominal Diameter12"
Bolt Circle Diameter11.97
Resonant Frequency (Fs)17.5Hz
Mechanical Q (Qms)6.23
Compliance Equivalent Volume (Vas)6.74ft³
Mechanical Compliance of Suspension (Cms)0.58mm/N
Diaphragm Mass Inc. Airload (Mms)142.6g
Maximum Linear Excursion (Xmax)13mm
Surface Area of Cone (Sd)480cm²
Cone MaterialAluminum
Overall Outside Diameter12.36"
Baffle Cutout Diameter10.71"
Depth3.5"
# Mounting Holes5
