  • Ciare CLOC4 Line Output Converter 4-Channel
NEW Ciare CLOC4 Line Output Converter 4-Channel
CiarePart # 293-198
Model: CLOC4
The Ciare CLOC4 4-channel output converter is designed to add aftermarket equipment to a factory-installed head unit. It combines input summing, differential balanced inputs, independent variable gains, selectable ground isolation, and multiple turn-on options for more flexible OEM integration.
  • Input summing for creating a full-range signal from actively crossed-over factory outputs
  • Differential balanced inputs for cleaner integration with factory speaker-level signals
  • Independent variable gains for better level matching to aftermarket equipment
  • Selectable ground isolation for helping reduce noise and ground loop issues
  • Selectable signal sense DC offset or 12V turn-on for more installation flexibility
  • Load detection for compatibility with factory audio systems that monitor speaker loads
  • 10V max output voltage for strong signal delivery to low-level RCA inputs
NEW $59.99
MSRP: $79.99
Save $20.00 (25%)
We'll send you an email when Ciare CLOC4 Line Output Converter 4-Channel is back in stock or available for preorder.
  • Input summing
  • Differential Balanced Inputs
  • Independent Variable Gains
  • Selectable Ground Isolation
  • Load Detection
  • Selectable signal sense, DX Offset or 12v+ Turn On
  • Channels In/Out: 4-channel
  • Operating Voltage: 8-16V
  • Current Draw, No Signal: 100mA
  • Input Impedance: 1kΩ
  • Max Output Voltage: 10V
  • Channel Separation: ≥60dB
  • Output THD: 0.01%
  • Sig/Noise: ≥100dB
  • REM Current: 12V, >500mA
  • Frequency Response: 10Hz~50kHz ±3dB
  • Input Voltage: <40V
  • Dimensions: 98.4 x 90 x 25mm (3.9" x 3.5" x 1")
BrandCiare
ModelCLOC4
Part Number293-198
UPC8054752269729
Weight0.7
Output Channels4
