NEW Ciare CLOC2 Line Output Converter 2-Channel
The Ciare CLOC2 2-channel output converter is designed to add aftermarket equipment to a factory-installed head unit. It combines input summing, differential balanced inputs, independent variable gains, selectable ground isolation, and multiple turn-on options for more flexible OEM integration.
- Input summing for creating a full-range signal from actively crossed-over factory outputs
- Differential balanced inputs for cleaner integration with factory speaker-level signals
- Independent variable gains for better level matching to aftermarket equipment
- Selectable ground isolation for helping reduce noise and ground loop issues
- Selectable signal sense DC offset or 12V turn-on for more installation flexibility
- Load detection for compatibility with factory audio systems that monitor speaker loads
- 10V max output voltage for strong signal delivery to low-level RCA inputs
We'll send you an email when Ciare CLOC2 Line Output Converter 2-Channel is back in stock or available for preorder.
