NEW Ciare C1A1200 Powersport Series Class D Monoblock Amplifier
The Ciare C1A1200 is a Class D monoblock subwoofer amplifier built for high-output bass systems with support for speaker loads down to 1Ω. It combines a MOSFET pulse width modulated power supply, variable low-pass and subsonic filtering, variable bass boost, and both RCA low-level and high-level input options for more flexible system integration.
- Stable down to a 1Ω load for compatibility with demanding subwoofer systems
- Low-pass filter from 50 Hz to 250 Hz for better subwoofer blending
- Subsonic filter from 15 Hz to 35 Hz for added low-frequency control
- Bass boost from 0 dB to 12 dB at 45 Hz for adjustable bass emphasis
- RCA low-level and high-level inputs for easier integration with different sources
- Auto turn-on when using high-level inputs for ease of use
- Remote subwoofer level control for quick bass adjustment
We'll send you an email when Ciare C1A1200 Powersport Series Class D Monoblock Amplifier is back in stock or available for preorder.
