  • Audtek VC-R50S Stereo Rotary Speaker Volume Control 2 x 50W with Impedance Matching
Audtek ElectronicsPart # 300-555
Model: VC-R50S
The Audtek VC-R50S Impedance Matching Rotary 2 x 50W Volume Control gives you 12 indented attenuation steps for use with any combination of 4, or 8 Ohm speakers. Independent grounds allow you to use the volume control with any amplifier.
  • 12 indented attenuation steps from no signal to full signal with no signal quality loss
  • Impedance matching design for use with any combination of 4, or 8 Ohm speaker
  • Fits into most deep single gang electrical junction boxes
  • Independent grounds allow you to use with any amplifier
  • Includes matching white wall plate
Your Price: $20.98
MSRP: $24.99
Save $4.01 (16%)
We'll send you an email when Audtek VC-R50S Stereo Rotary Speaker Volume Control 2 x 50W with Impedance Matching is back in stock or available for preorder.
Control up to 28 speakers with an 8 Ohm amplifier
The Audtek VC-50RS Impedance Matching Rotary 2 x 50W Volume Control is a fantastic solution for anyone looking to enhance their audio experience. With its 12 indented attenuation steps, this volume control allows you to fine-tune the stereo sound output to perfectly match your listening preferences. Whether you’re using 4 or 8 Ohm speakers, the VC-50RS ensures seamless compatibility, making it a versatile addition to your multiroom or large conference room audio setup.
Impedance Matching Versatility
The Audtek VC-50RS is an impressive volume control solution that meets the demands of multi-speaker stereo audio setups. If you're considering controlling multiple speakers' volume in a large room or throughout multiple rooms, this device is an excellent choice to protect your audio amplifier from potential damage caused by impedance mismatches. The chart below gives you an idea of how many speakers you are available to use for each channel. You must determine if your amp's design is for 4 Ohm or 8 Ohm speakers. Notice that 8 Ohm speakers enable you to use more whether your amp is 4 Ohm or 8 Ohm. For example, using the 8 Ohm amp Chart B, your able to hookup eight 8 Ohm speakers and four 4 Ohm speakers at the same time. Notice the picture under Chart A and B has the switch set to 4x, which is also the fourth position.
One of the standout features of this volume control is its independent grounds. This design allows it to work effortlessly with any amplifier, which means you can integrate it into your existing system without a hitch. Whether you’re setting up a multi-room audio system, or a large room sound setup, the VC-50RS gives you the flexibility and control you need.
Note: Make sure the 1-Gang electrical box is at least 3.188" (81 mm) deep.
Type: Rotary impedance matching
Power handling: 2 x 50W
Speaker impedance: 4, 8 Ohms
Attenuation steps: 12 (step 1 is no signal, steps 2-7 at 3 dB each, step 8-11 at 6 dB each, step 12 is full signal)
Frequency response: 35-20,000 Hz
Input / output connections: Phoenix-type, up to 14-gauge speaker cable
Size: Standard deep single gang
Color: White (RAL9003)
TotalDimensions: 4" D x 1-7/8" W x 2-7/8 H (102 x 72.16 x 46.27 mm) without wall plate
Mounting depth with phoenix type plugs: 3-3/16" (81 mm)
BrandAudtek Electronics
ModelVC-R50S
Part Number300-555
UPC848864077635
Weight1.25
Control SurfaceRotary Knob
Wall Plate ColorWhite
