  • Audtek VC-50S Impedance Matching Sliding Speaker Volume Control 50W
CLEARANCE Audtek VC-50S Impedance Matching Sliding Speaker Volume Control 50W
Audtek ElectronicsPart # 300-567
Model: VC-50S
The Audtek VC-50S Impedance Matching Sliding 50W Volume Control gives you 12 indented attenuation steps for use with any combination of 4, 8, or 16-ohm speakers. Independent grounds allow you to use the volume control with any amplifier.
  • 12 indented attenuation steps from no signal to full signal with no signal quality loss
  • Impedance matching design for use with any combination of 4, 8, or 16-ohm speakers
  • Fits into most deep single gang electrical junction boxes
  • Independent grounds allow you to use with any amplifier
  • Includes matching white wall plate
  • Sliding control makes the volume level easier to see at distance
CLEARANCE $10.63
Save $14.36 (57%)
37 In Stock
We'll send you an email when Audtek VC-50S Impedance Matching Sliding Speaker Volume Control 50W is back in stock or available for preorder.
Order in the next 3 hr 19 min to ship today. Details
The Audtek VC-50S Impedance Matching Sliding 50W Volume Control gives you 12 indented attenuation steps for use with any combination of 4, 8, or 16-ohm speakers. Impedance matching design allows you to use the control with any combination of 4, 8, or 16-ohm speakers. Easily adjust impedance by adjusting the position of two shorting bars. High-quality components ensure no signal quality loss while attenuating. A broad frequency response retains a tight low-end response and crisp highs. Phoenix-type connectors accept up to 14 AWG to simplify the installation process.
• Type: Sliding impedance matching
• Power handling: 2 x 50W
• Speaker impedance: 4, 8, 16 ohms
• Attenuation steps: 12 (step 1 is no signal, steps 2-7 at 3 dB each, step 8-11 at 6 dB each, step 12 is full signal)
• Frequency response: 35-20,000 Hz
• Input / output connections: Phoenix-type, up to 14-gauge speaker cable
• Size: Standard single gang
• Dimensions: 4" x 1-3/4" x 3"
BrandAudtek Electronics
ModelVC-50S
Part Number300-567
UPC848864063812
Weight0.95
Control SurfaceSliding Mechanism
Wall Plate ColorWhite
