  • 2 Pole Single Row Solder Lug Type Barrier Terminal Strip with Cover
Parts ExpressPart # 090-834
Terminal blocks provide a convenient means of connecting individual electrical wires without the use of a splice or having to physically join wire ends. This one includes a plastic cover to prevent accidental short circuits.
  • The base is heavy duty PA 66 (UL94V-0) thermoplastic for durability
  • Nickel plated screws for moisture resistance
  • Slide on clear cover to prevent accidental short circuit and electrical shock
  • Accepts fork/ring connectors up to 0.32" (8.2 mm) wide
  • Clamping action keeps bare wire from squirting out from under the screw
Your Price: $1.69
Quantity:Qty: 1-9 $1.69/ea
Quantity:Qty: 10+ $1.53/ea
416 In Stock
We'll send you an email when 2 Pole Single Row Solder Lug Type Barrier Terminal Strip with Cover is back in stock or available for preorder.
Single row, 2 pole solder type barrier strip with clear cover makes the perfect safe wiring junction. Made from heavy duty PA 66 (UL94V-0) thermoplastic, this barrier strip can handle 25A of current and 300V. Accepts 22-12 AWG wire in the 9.5 mm pitch terminal. Operating temperature is -67°~221°F (-55°~105°C). Terminals are tin plated brass and the M3.5 screws are nickel plated steel for moisture resistance. Total size is 1.59" W x 0.64" D x 0.75" H without terminals. Terminals measure 0.17" W x 0.32" D x 0.35" H and have 0.206" of space between each one. Mounting holes are 0.13" diameter and 1.1" apart from center.
Part Number090-834
UPC848864051673
Weight0.03
