  • Wavecor WF182BD18 7" Black Coated Paper/Glass Fiber Cone Midwoofer 8 Ohm
NEW Wavecor WF182BD18 7" Black Coated Paper/Glass Fiber Cone Midwoofer 8 Ohm
WavecorPart # 298-1236
Model: WF182BD18
The 7″ WF182BD18 transducer was developed as a high-performance bass and midrange driver for monitors and high-end hi-fi loudspeakers. It delivers impressive deep bass along with a dynamic and detailed midrange response.
  • Balanced Drive motor system ensures symmetrical force for significantly reduced even-order harmonic distortion
  • Paper/glass fiber cone blend provides enhanced material consistency and structural stability
  • Sturdy die-cast aluminum chassis with generous venting reduces air turbulence and audible distortion
  • Reinforced fiberglass voice coil former decreases mechanical losses for improved dynamics and low-level detail
  • Integrated aluminum field-stabilizing ring reduces distortion at higher output levels
  • Black-coated motor parts promote better heat dissipation into the surrounding air
  • Gold-plated terminals resist corrosion and provide a long-lasting, dependable connection
Wavecor WF182BD14 7" Kevlar/Carbon Fiber Cone Midwoofer 8 Ohm
Price: $211.00Part # 298-1234
NEW $163.00
We'll send you an email when Wavecor WF182BD18 7" Black Coated Paper/Glass Fiber Cone Midwoofer 8 Ohm is back in stock or available for preorder.
Order in the next 13 hr 14 min to ship today. Details
The WF182BD18 is designed with a Balanced Drive motor structure that ensures symmetrical magnetic force, significantly reducing even-order harmonic distortion for cleaner sound reproduction. A copper cap on the center pole lowers voice coil inductance and minimizes variations in inductance as the coil moves, improving linearity and high-frequency response. The cone is constructed from a new paper and glass fiber blend, providing improved consistency, stability, and natural tonal balance. A rigid die-cast aluminum chassis with extensive venting reduces air turbulence and audible distortion, while the vented voice coil former and dual-flared center pole help to minimize compression and noise during large cone excursions.
The heavy-duty black fiberglass voice coil former reduces mechanical losses, enhancing dynamic performance and low-level detail. A large motor with a 39 mm voice coil provides better control and high power handling, while an integrated aluminum field-stabilizing ring keeps distortion low at elevated output levels. The low-loss suspension, featuring a high mechanical Q, contributes to detailed and dynamic sound reproduction. Black-coated motor components improve heat dissipation, and the rugged Conex spider ensures long-term durability even under demanding conditions. Gold-plated terminals offer a reliable, corrosion-resistant connection for years of trouble-free use.
Measuring conditions, SPL
Driver mounting: Flush in infinite baffle, back side open (no cabinet)
Microphone distance: 1.0 m
Input signal: 2.83 VRMS
Smoothing: 1/6 oct.
Measuring conditions, impedance
Driver mounting: Free air, no baffle, back side open (no cabinet)
Input signal: Stepped sine wave, semi-current-drive, nominal current 2 mA
Smoothing: None
Measuring conditions, harmonic distortion
Driver mounting: In sealed enclosure, internal volume 5 lit.,
Microphone distance: 0.5 m
Input signal: Stepped sine wave, 7.75 VRMS
Smoothing: 1/12 oct.
BrandWavecor
ModelWF182BD18
Part Number298-1236
UPC848864081212
Weight5.1
Nominal Diameter7"
Power Handling (RMS)80 Watts
Power Handling (MAX)160 Watts
Sensitivity86dB 2.83V/1m
Voice Coil Diameter1.54"
Resonant Frequency (Fs)29.5Hz
Mechanical Q (Qms)8.8
Electromagnetic Q (Qes)0.38
Total Q (Qts)0.37
Compliance Equivalent Volume (Vas)1.14ft³
Mechanical Compliance of Suspension (Cms)1.33mm/N
Diaphragm Mass Inc. Airload (Mms)21.9g
Maximum Linear Excursion (Xmax)5.5mm
Surface Area of Cone (Sd)131cm²
Cone MaterialCarbon Fiber / Kevlar
Voice Coil FormerFiberglass
Overall Outside Diameter7.16"
Baffle Cutout Diameter6.02"
Depth3.23"
# Mounting Holes6
