  • Wavecor WF182BD14 7" Kevlar/Carbon Fiber Cone Midwoofer 8 Ohm
NEW Wavecor WF182BD14 7" Kevlar/Carbon Fiber Cone Midwoofer 8 Ohm
WavecorPart # 298-1234
Model: WF182BD14
The 7″ WF182BD14 transducer was developed as a high-performance bass and midrange driver for use in compact monitor designs and premium hi-fi loudspeakers.
  • Interwoven Kevlar/Carbon fiber cone combines low mass, stiffness, and damping to improve midrange performance
  • Vented, inverted center dome lowers compression effects
  • Sturdy die-cast aluminum chassis with extensive venting decreases airspeed and audible distortion
  • Reinforced black fiberglass voice coil former minimizes mechanical losses and enhances dynamics and fine detail
  • Integrated aluminum field-stabilizing ring reduces distortion at elevated output levels
  • Durable CONEX spider ensures longevity under demanding conditions
  • Gold-plated terminals resist oxidation and provide a reliable long-term connection
NEW $211.00
We'll send you an email when Wavecor WF182BD14 7" Kevlar/Carbon Fiber Cone Midwoofer 8 Ohm is back in stock or available for preorder.
Order in the next 11 hr 27 min to ship today. Details
The WF182BD14 features a newly developed cone made from interwoven Kevlar and carbon fibers, offering an ideal blend of low mass, rigidity, and internal damping. These characteristics make it especially well-suited for detailed and accurate midrange reproduction. The Balanced Drive motor structure promotes symmetrical drive force, which significantly reduces even-order harmonic distortion. A vented, inverted center dome helps minimize compression, while the copper cap on the center pole lowers inductance and keeps it stable throughout the voice coil's excursion. The rigid die-cast aluminum chassis includes extensive venting to control airflow and reduce turbulence-related distortion.
A heavy-duty black fiberglass voice coil former is used to reduce mechanical losses, contributing to improved dynamics and clarity at low levels. The large motor includes a 1.25” diameter voice coil for better control and increased power handling, while an aluminum field-stabilizing ring keeps distortion low even at high output. A low-loss suspension with high mechanical Q improves detail retrieval and transient accuracy. Black-coated motor components enhance heat dissipation, and the Conex spider is built to withstand demanding conditions. Gold-plated terminals offer long-term reliability by preventing oxidation and maintaining a secure electrical connection.
Measuring conditions, SPL
Driver mounting: Flush in infinite baffle, back side open (no cabinet)
Microphone distance: 1.0 m
Input signal: 2.83 VRMS LogChirp, 64k, Hanning/2
Smoothing: 1/6 oct.
Measuring conditions, impedance
Driver mounting: Free air, no baffle, back side open (no cabinet)
Input signal: Stepped sine wave, semi-current-drive, nominal current 2 mA
Smoothing: None
Measuring conditions, harmonic distortion
Driver mounting: In sealed enclosure, internal volume 5 lit.
Microphone distance: 0.5 m
Input signal: Stepped sine wave, 8.0 VRMS
Smoothing: 1/12 oct.
BrandWavecor
ModelWF182BD14
Part Number298-1234
UPC848864081199
Weight6
Nominal Diameter7"
Power Handling (RMS)80 Watts
Power Handling (MAX)160 Watts
Sensitivity88dB 2.83V/1m
Voice Coil Diameter1.25"
Resonant Frequency (Fs)37Hz
Mechanical Q (Qms)10.3
Electromagnetic Q (Qes)0.31
Total Q (Qts)0.3
Compliance Equivalent Volume (Vas)0.81ft³
Mechanical Compliance of Suspension (Cms)1.18mm/N
Diaphragm Mass Inc. Airload (Mms)15.6g
Maximum Linear Excursion (Xmax)5.5mm
Surface Area of Cone (Sd)117cm²
Cone MaterialCarbon Fiber / Kevlar
Voice Coil FormerFiberglass
Overall Outside Diameter7.16"
Baffle Cutout Diameter6.02"
Depth3.31"
# Mounting Holes6
