  • Wavecor WF152BD14 6" Black Coated Paper/Glass Fiber Cone Midwoofer 8 Ohm
NEW Wavecor WF152BD14 6" Black Coated Paper/Glass Fiber Cone Midwoofer 8 Ohm
WavecorPart # 298-1232
Model: WF152BD14
The WF152BD14 is a 6″ transducer that was developed as a high-performance bass and midrange driver for compact monitor systems and premium hi-fi loudspeakers.
  • Balanced Drive motor design provides symmetrical drive force to significantly reduce even-order harmonic distortion
  • New black-coated cone made from a paper and glass fiber blend offers enhanced stability and consistency
  • Sturdy die-cast aluminum frame with generous venting reduces air speed to minimize audible distortion
  • Integrated aluminum field-stabilizing ring reduces distortion during high-level playback
  • Low-loss suspension (high Qm) enhances detail retrieval and dynamic performance
  • Black motor components enhance heat transfer for improved thermal management
  • Gold-plated terminals resist oxidation for dependable long-term connectivity
Wavecor WF152BD10 6" Kevlar/Carbon Fiber Cone Midwoofer 8 Ohm
Price: $147.00Part # 298-1230
NEW $131.00
We'll send you an email when Wavecor WF152BD14 6" Black Coated Paper/Glass Fiber Cone Midwoofer 8 Ohm is back in stock or available for preorder.
Order in the next 13 hr 14 min to ship today. Details
The WF152BD14 is built around a Balanced Drive motor structure, delivering symmetrical magnetic force to greatly reduce even-order harmonic distortion for cleaner sound reproduction. A copper cap on the center pole lowers inductance and stabilizes its variation across coil position, improving linearity and high-frequency behavior. The new black-coated cone, made from a paper and glass fiber blend, offers improved consistency and structural stability, supported by a rigid die-cast aluminum chassis with extensive venting to reduce air turbulence and audible distortion. Both the voice coil former and center pole are vented and feature dual flares on the pole piece to reduce compression and noise during large excursions. A heavy-duty black fiberglass former minimizes mechanical losses, while the large 1.25" voice coil and integrated aluminum field-stabilizing ring provide excellent power handling and low distortion under high-output conditions. Additional features include a low-loss suspension for enhanced transient response, black-coated motor parts for improved thermal performance, a rugged CONEX spider for long-term durability, and gold-plated terminals for secure, corrosion-resistant connections.
Measuring conditions, SPL
Driver mounting: Flush in infinite baffle, back side open (no cabinet)
Microphone distance: 1.0 m
Input signal: 2.83 VRMS
Smoothing: 1/6 oct.
Measuring conditions, impedance
Driver mounting: Free air, no baffle, back side open (no cabinet)
Input signal: Semi-current-drive, nominal current 2 mA
Smoothing: None
BrandWavecor
ModelWF152BD14
Part Number298-1232
UPC848864081175
Weight3.55
Nominal Diameter6"
Power Handling (RMS)100 Watts
Power Handling (MAX)200 Watts
Sensitivity87dB 2.83V/1m
Voice Coil Diameter1.26"
Resonant Frequency (Fs)46Hz
Mechanical Q (Qms)8
Electromagnetic Q (Qes)0.36
Total Q (Qts)0.35
Compliance Equivalent Volume (Vas)0.41ft³
Mechanical Compliance of Suspension (Cms)0.94mm/N
Diaphragm Mass Inc. Airload (Mms)12.8g
Maximum Linear Excursion (Xmax)4.5mm
Surface Area of Cone (Sd)93cm²
Voice Coil FormerFiberglass
Baffle Cutout Diameter4.01"
Depth2.95"
