  • Wavecor WF152BD09 6" Kevlar/Carbon Fiber Cone Midwoofer 4 Ohm
NEW Wavecor WF152BD09 6" Kevlar/Carbon Fiber Cone Midwoofer 4 Ohm
WavecorPart # 298-1229
Model: WF152BD09
The WF152BD09 6″ transducer was developed as a high-performance bass and midrange driver for compact monitor and premium hi-fi speaker applications.
  • New interwoven Kevlar/Carbon fiber cone combines low mass, rigidity, and damping for an ideal midrange performance
  • Vented, inverted center dome reduces dynamic compression
  • Rigid die-cast aluminum chassis with ample venting decreases air velocity and audible distortion
  • Durable black fiberglass voice coil former minimizes mechanical losses, enhancing dynamics and low-level detail
  • Integrated aluminum field-stabilizing ring minimizes high-level distortion
  • Black-coated motor parts promote better heat dissipation to the surrounding air
  • Gold-plated terminals provide long-lasting, reliable electrical connection
NEW $147.00
We'll send you an email when Wavecor WF152BD09 6" Kevlar/Carbon Fiber Cone Midwoofer 4 Ohm is back in stock or available for preorder.
The WF152BD09 is a midrange driver featuring a newly developed cone made from interwoven Kevlar and carbon fibers, offering a class-leading combination of low mass, rigidity, and internal damping for an accurate and detailed midrange reproduction. Its Balanced Drive motor structure delivers symmetrical magnetic force for significantly reduced even-order harmonic distortion, while a vented, inverted center dome lowers compression during high-output operation. The center pole is capped with copper to reduce voice coil inductance and stabilize its behavior across excursion, contributing to a smoother, more linear response. A rigid die-cast aluminum chassis with extensive venting controls air flow velocity to limit turbulence-related distortion, and a 1.25" voice coil wound on a black fiberglass former helps improve dynamic performance by reducing mechanical losses. Additional enhancements include an integrated aluminum field-stabilizing ring for low distortion at high SPL, a high-Qm suspension system for refined detail and transient response, and black-coated motor parts that aid heat dissipation. The Conex spider ensures long-lasting mechanical durability under demanding conditions, while gold-plated terminals provide a corrosion-resistant, reliable electrical connection over time.
Measuring conditions, SPL
Driver mounting: Flush in infinite baffle, back side open (no cabinet)
Microphone distance: 1.0 m
Input signal: 2.83 VRMS LogChirp, 64k, Hanning/2
Smoothing: 1/6 oct.
Measuring conditions, impedance
Driver mounting: Free air, no baffle, back side open (no cabinet)
Input signal: Stepped sine wave, semi-current-drive, nominal current 2 mA
Smoothing: None
Measuring conditions, harmonic distortion
Driver mounting: In sealed enclosure, internal volume 2 lit.
Microphone distance: 0.5 m
Input signal: Stepped sine wave, 5.3 VRMS
Smoothing: 1/12 oct.
BrandWavecor
ModelWF152BD09
Part Number298-1229
UPC848864081144
Weight4.2
Nominal Diameter6"
Power Handling (RMS)70 Watts
Power Handling (MAX)140 Watts
Sensitivity90dB 2.83V/1m
Voice Coil Diameter1.26"
Resonant Frequency (Fs)49Hz
Mechanical Q (Qms)10.5
Electromagnetic Q (Qes)0.33
Total Q (Qts)0.32
Compliance Equivalent Volume (Vas)0.34ft³
Mechanical Compliance of Suspension (Cms)0.94mm/N
Diaphragm Mass Inc. Airload (Mms)11g
Maximum Linear Excursion (Xmax)4.5mm
Surface Area of Cone (Sd)85cm²
Cone MaterialCarbon Fiber / Kevlar
Voice Coil FormerFiberglass
Baffle Cutout Diameter4.33"
Depth2.95"
