  • Visaton R10STE4 4" Full-Range Speaker 8 Ohm
CLEARANCE Visaton R10STE4 4" Full-Range Speaker 8 Ohm
VisatonPart # 292-7813
Model: R 10 S TE
The Visaton R00STE4 is a compact 10 cm (4") full-range speaker designed for high efficiency and reliable performance in control and monitoring applications. Known for its balanced frequency response, the speaker is ideally suited for use in electronic devices, ceiling-mounted speaker systems in public transportation, and even model construction projects. Its rugged design and IP53-rated protection against dust and splashing water make it a durable choice for challenging environments, ensuring consistent performance in demanding use cases.
  • Frequency response from 100 Hz to 13,000 Hz for broad sound reproduction
  • Mean sound pressure level of 90 dB (1 W/1 m) for efficient output
  • Resonance frequency at 160 Hz for clear and natural sound quality
  • Excursion limit of ±1.5 mm for controlled diaphragm movement
  • Operating temperature range from −40 to 70 °C for use in varied environments
  • IP53-rated protection against dust and splashing water for durability
Visaton FR10-4 4" Paper Cone Full-Range Driver 4 Ohm
Price: $17.97Part # 292-700
CLEARANCE $12.26
3 In Stock
We'll send you an email when Visaton R10STE4 4" Full-Range Speaker 8 Ohm is back in stock or available for preorder.
The R10STE8 is an updated version of the R10S8. Its robust construction includes a waterproof membrane and optimized mechanical properties to ensure reliable performance over time. With its compact size and lightweight design, it is ideal for integrating into tight spaces without compromising on sound quality. Whether for industrial monitoring systems, public transportation, or creative model construction, the R10STE8  delivers consistent and efficient sound performance tailored to your needs.
Technical Data
  • Rated power: 20 W
  • Maximum power: 30 W
  • Nominal impedance Z: 4 Ohm
  • Frequency response: 100–1300 Hz
  • Mean sound pressure level: 90 dB (1 W/1 m)
  • Opening angle (-6 dB): 92°/4000 Hz
  • Excursion limit: ±1.5 mm
  • Resonance frequency fs: 160 Hz
  • Magnetic induction: 0.95 T
  • Magnetic Flux: 135 µWb
  • Height of front pole-plate: 3 mm
  • Voice coil diameter: 15 mm
  • Height of winding: 4 mm
  • Cutout diameter: 93 mm
  • Net weight: 0.16 kg
  • D.C. resistance Rdc: 7.2 Ohm
  • Mechanical Q factor Qms: 6.27
  • Electrical Q factor Qes: 2.92
  • Total Q factor Qts: 1.99
  • Equivalent volume Vas: 1.7 l
  • Effective piston area Sd: 56 cm²
  • Dynamically moved mass Mms: 2 g
  • Force factor Bxl: 2.0 T m
  • Inductance of the voice coil L: 0.5 mH
  • Connections: 4.8 x 0.8 mm (+)/2.8 x 0.8 mm (-)
  • Protective system: IP 53
  • Temperature range: -40 - 70 °C
BrandVisaton
ModelR 10 S TE
Part Number292-7813
Weight0.35
Nominal Diameter4"
Power Handling (RMS)20 Watts
Power Handling (MAX)30 Watts
Frequency Response100-1300Hz
Sensitivity90dB 2.83V/1m
Voice Coil Diameter0.59"
Resonant Frequency (Fs)160Hz
DC Resistance (Re)7.2Ω
Voice Coil Inductance (Le)2mH
Mechanical Q (Qms)6.27
Electromagnetic Q (Qes)2.92
Total Q (Qts)1.99
Compliance Equivalent Volume (Vas)0.06ft³
BL Product (BL)2T·m
Diaphragm Mass Inc. Airload (Mms)2g
Maximum Linear Excursion (Xmax)1.5mm
Surface Area of Cone (Sd)56cm²
