  • Visaton R10SCSpezial8 4" Magnetically Shielded Full-Range Speaker 8 Ohm
VisatonPart # 292-7815
Model: R 10 SC Spezial
The Visaton R10SCSpezial8 is a magnetically shielded 10 cm (4") full-range speaker designed for high efficiency and reliable performance in various audio applications. With its water-repellent cone, robust construction, and IP64-rated protection, this speaker is engineered to operate in challenging environments such as public transport systems and industrial setups. Its balanced frequency response and ability to perform in extreme temperatures make it ideal for applications demanding consistent and durable audio performance.
  • Magnetic shielding to prevent interference with nearby electronics
  • Water-repellent cone and rubber gasket for enhanced durability in various conditions
  • Balanced 100-13000Hz frequency response for clear and consistent audio output
  • Operating temperature range from −40 to +70 °C for dependable performance in extreme conditions
  • IP64-rated protection against dust and splashing water for reliable outdoor and industrial use
Visaton FR 10-8 4" Full-Range Speaker
Price: $17.97Part # 292-513
Your Price: $14.02
We'll send you an email when Visaton R10SCSpezial8 4" Magnetically Shielded Full-Range Speaker 8 Ohm is back in stock or available for preorder.
The R10SCSpezial8 is built to meet the demands of harsh environments, featuring IP64-rated protection against environmental elements such as dust and splashing water. Its wide operating temperature range ensures reliable functionality in both hot and cold conditions, while magnetic shielding prevents interference when placed near sensitive electronics. This speaker is an excellent choice for public transport systems, control devices, or industrial installations where rugged and efficient audio performance is critical.
Technical Data
  • Rated power: 20 W
  • Maximum power: 30 W
  • Nominal impedance Z: 8 Ohm
  • Frequency response: 100–13000 Hz
  • Mean sound pressure level: 90 dB (1 W/1 m)
  • Opening angle (-6 dB): 92°/4000 Hz
  • Excursion limit: +/−1.5 mm
  • Resonance frequency fs: 165 Hz
  • Magnetic induction: 0.95 T
  • Magnetic flux: 135 µWb
  • Height of front pole-plate: 3 mm
  • Voice coil diameter: 15 mm
  • Height of winding: 4 mm
  • Cutout diameter: 93 mm
  • Net weight: 0.24 kg
  • D.C. resistance Rdc: 7.4 Ohm
  • Mechanical Q factor Qms: 5.3
  • Electrical Q factor Qes: 2.63
  • Total Q factor Qts: 1.76
  • Equivalent volume Vas: 2.3 l
  • Effective piston area Sd: 56 cm²
  • Dynamically moved mass Mms: 2.2 g
  • Force factor Bxl: 2.4 T m
  • Inductance of the voice coil L: 0.5 mH
  • Connections: 6.3 x 0.8 mm (+)/4.8 x 0.8 mm (-)
  • Protective system: IP 64 *)
  • Temperature range: −40 - 70 °C
BrandVisaton
ModelR 10 SC Spezial
Part Number292-7815
Weight0.59
Nominal Diameter4"
Power Handling (RMS)20 Watts
Power Handling (MAX)30 Watts
Frequency Response100-13000Hz
Sensitivity90dB 2.83V/1m
Voice Coil Diameter0.59"
Resonant Frequency (Fs)165Hz
DC Resistance (Re)7.4Ω
Voice Coil Inductance (Le)0.5mH
Mechanical Q (Qms)5.3
Electromagnetic Q (Qes)2.63
Total Q (Qts)1.76
Compliance Equivalent Volume (Vas)0.08ft³
BL Product (BL)2.4T·m
Diaphragm Mass Inc. Airload (Mms)2.2g
Maximum Linear Excursion (Xmax)1.5mm
Surface Area of Cone (Sd)56cm²
