  • Sonic Barrier Acousta-Blue+ Speaker Cabinet Sound Damping Denim Fiber + 1 lb. Mat Vinyl 15 Sq. ft.
Sonic BarrierPart # 260-570
Acousta-Blue+ enhance the clarity of your sound by reducing standing waves just like Acousta-Blue, but it also eliminates annoying cabinet vibrations. These vibrations can often create unwanted rattling or buzzing noises, detracting from the overall audio experience. With Acousta-Blue+, you can say goodbye to these distractions and enjoy a smooth and immersive listening experience.
  • Peel-n-stick makes easy to apply the sheets right to speaker cabinet walls without glue, gloves, mask and glasses
  • Recycled denim doesn't dry out over long periods of time ensuring long-lasting, consistent results
  • NCR rating is 30% better than the same thickness of fiberglass insulation at absorbing standing waves and the 1 lb. vinyl dampens the cabinet wood from ambient vibrations
  • Eco-friendly non-carcinogenic itch-free recycled material
  • Resistant to rodents, insects, fungi, and mildew
  • Class A fire rating for safety and Made in USA
  • Made in convenient sheets 40" x 53.5" (15 Sq. ft.) with 1.18" thick denim and 0.12" thick vinyl
Your Price: $99.98
Order in the next 11 hr 38 min to ship today. Details
Dual Purpose Sound Isolation
Acousta-Blue+ still isolates and traps sound waves, but also prevents the wood in speaker cabinets from producing ambient noises. The vinyl portion dramatically reduces vibration energy that would normally be stored in the walls of the cabinet. By preventing unwanted standing wave frequencies inside speaker cabinets and annoying rattling or buzzing sounds that often accompany speaker systems, it significantly improves the quality of sound output. The result? Clearer, more accurate audio reproduction that truly captivates your senses.
Acousta-Blue+ still boasts a Noise Reduction Coefficient (NRC) rating that is 30% better than fiberglass in thicknesses less than 3". This means it provides superior sound absorption, effectively reducing standing waves within the speaker cabinet. The graph below shows the NRC for Acousta-Blue 30 mm (1.18") vs 50 mm (1.97").
The 30 mm (1.18") thickness combined with the 1 lb. vinyl is perfectly suited for large bass reflex speaker/subwoofer cabinets. Acousta-Blue+ helps reduce the need for extra thick wood in your speaker build. The added 1 lb. vinyl adds mass to the speaker cabinet which reduces vibrations that thinner wood would have. The peel-n-stick application and denim material eliminates the need for glue, mask, and gloves which other materials like fiberglass require.
Considering these advantages, it's clear that Sonic Barrier's Acousta-Blue+ is the superior choice for your next large size speaker project. Its ability to control sound, superior NRC rating, safe composition, and ideal thickness make it the perfect solution. Don't settle for anything less than the best when it comes to building your speakers. Choose Acousta-Blue+ and experience the difference in sound quality.
Environmentally Friendly
Acousta-Blue stands apart from other damping materials due to its exceptional features and eco-friendly nature. One key factor is its use of recycled denim, making it a sustainable choice that prevents denim from ending up in landfills. Not only does this contribute to environmental preservation, but the recycling process also enhances the material's resistance to flames, rodents, insects, fungi, and mildew. Unlike other traditional damping materials like foam which has similar NRC, Acousta-Blue does not dry out over time, ensuring long-lasting and consistent results. By choosing Acousta-Blue, you not only benefit from better damping and durability but also create a healthier indoor environment.
Note: Use a utility knife to cut the vinyl and cut Acousta-Blue denim with carpet shears, sharp large fabric scissors, or high quality electrician scissors for best results.
Specifications: • Material makeup: 75% denim and 25% binders • NCR rating at 5 kHz: 1.0 • Size: 40" W x 53.5" L (1016 x 1219 mm) • Denim thickness: 1.18" (30 mm) • Vinyl thickness 0.12" (3 mm).
BrandSonic Barrier
Part Number260-570
UPC848864074979
Weight24.1
