  • Sonic Barrier Acousta-Blue Speaker Cabinet Sound Damping Denim 50mm x 40" x 48"
Sonic BarrierPart # 260-568
Sonic Barrier's Acousta-Blue - the ultimate solution for eliminating unwanted sound waves in your speaker cabinets. Say goodbye to the irritating frequencies bouncing around that compromise your audio quality. With Acousta-Blue, you can experience unparalleled clarity and precision in your sound reproduction.
  • Easy to work with sheets that hold together when glued to speaker cabinet walls
  • Recycled denim doesn't dry out over long periods of time ensuring long-lasting, consistent results
  • NCR rating is 30% better than the same thickness of fiberglass insulation
  • Eco-friendly non-carcinogenic itch-free recycled material
  • Recycling process makes it resistant to rodents, insects, fungi, and mildew
  • Class A fire rating for safety and Made in USA
  • Made in convenient sheets 40" x 48" (13.3 Sq. ft.) 1.97" thick
Your Price: $59.98
Order in the next 3 hr 35 min to ship today. Details
Sonic Barrier's Acousta-Blue vs. Other Speaker Cabinet Damping Material
Firstly, Acousta-Blue's ability to isolate and trap sound waves sets it apart. By preventing unwanted standing wave frequencies inside speaker cabinets, it significantly improves the quality of sound output. This means you can enjoy clearer and more accurate audio reproduction.
Additionally, Acousta-Blue boasts a Noise Reduction Coefficient (NRC) rating that is 30% better than fiberglass in thicknesses less than 3". This means it provides superior sound absorption, effectively reducing echoes within the speaker cabinet. The graph below shows the NRC for Acousta-Blue 30 mm (1.18") vs 50 mm (1.97").
Moreover, working with Acousta-Blue is hassle-free. Unlike fiberglass, it has no irritating carcinogenic filaments, making it safer and more comfortable to handle without using gloves, mask, and safety glasses. Its easy-to-work-with nature ensures a smooth installation process, saving you time and effort.
Lastly, the 50 mm (1.97") thickness of Acousta-Blue is perfectly suited for large bass reflex speaker/subwoofer cabinets. This size provides optimal sound control and helps achieve the desired sound performance.
Considering these advantages, it's clear that Sonic Barrier's Acousta-Blue is the superior choice for your next large size speaker project. Its ability to control sound, superior NRC rating, safe composition, and ideal thickness make it the perfect solution. Don't settle for anything less than the best when it comes to building your speakers. Choose Acousta-Blue and experience the difference in sound quality.
Environmentally Friendly
Acousta-Blue stands apart from other damping materials due to its exceptional features and eco-friendly nature. One key factor is its use of recycled denim, making it a sustainable choice that prevents denim from ending up in landfills. Not only does this contribute to environmental preservation, but the recycling process also enhances the material's resistance to flames, rodents, insects, fungi, and mildew. Unlike other traditional damping materials like foam which has similar NRC, Acousta-Blue does not dry out over time, ensuring long-lasting and consistent results. By choosing Acousta-Blue, you not only benefit from better damping and durability but also create a healthier indoor environment.
Note: Cut Acousta-Blue with carpet shears, sharp large fabric scissors, or high quality electrician scissors for best results.
Specifications: • Material makeup: 75% denim and 25% binders • NCR rating at 630 Hz: 1.0 • Size: 40" W x 48" L (1016 x 1219 mm) • Thickness: 1.97" (50 mm).
BrandSonic Barrier
Part Number260-568
UPC848864074962
Weight5.7
