  • Russound MIXAMP-60 60W 70V Mixer Amplifier with Bluetooth, FM, and MP3 Player
NEW Russound MIXAMP-60 60W 70V Mixer Amplifier with Bluetooth, FM, and MP3 Player
RussoundPart # 247-1916
Model: MIXAMP-60
The Russound MIXAMP-60 is a 70V/100V mixer amplifier with a built-in media player, designed for small commercial installations that need flexible, all-in-one audio control. It combines source selection, mixing, and amplification into one unit for easy operation in restaurants, offices, and retail spaces.
  • Integrated media player supports Bluetooth, FM radio, USB, and SD card sources
  • Three microphone inputs with priority control and phantom power on Mic 1
  • Four stereo line inputs for connecting multiple external audio devices
  • Front panel source selection and individual volume controls for simple operation
  • Dedicated zone output for connection to external amplifiers or powered subwoofers
  • 60-watt amplifier with selectable 70V, 100V, or low-impedance outputs
  • Compact 2U rack-mount design with included brackets for easy installation
NEW $425.00
We'll send you an email when Russound MIXAMP-60 60W 70V Mixer Amplifier with Bluetooth, FM, and MP3 Player is back in stock or available for preorder.
Order in the next 13 hr 1 min to ship today. Details
The MixAmp-60 Mixer Amplifier with MP3, FM tuner, and Bluetooth is ideal for schools, supermarkets, convenience stores, banks, retail shops, and similar settings. This all-in-one unit combines built-in audio sources, preamp mixing, audio amplification, and expandability for external sources and microphones, all housed in a compact, rack-mountable chassis.
The MixAmp-60 supports up to three microphones and four external audio sources in addition to its built-in FM tuner, Bluetooth receiver, USB, and SD card MP3 player.
Front panel controls provide precise volume adjustment for all connected inputs, while the integrated LCD display shows the active built-in source. Background Music (BGM) and Music On Hold (MOH) integration are included, along with a Telephone Paging Input. Phantom power is available for the primary microphone, and ducking levels can be easily adjusted for clear voice prioritization.
Versatile design to meet the most common installation needs
Perfect for background music, microphone use, and paging applications
All-in-one system featuring built-in Bluetooth, FM tuner, and portable media support, with connections for up to four external sources
Equipped with the right connections for quick and efficient installation
Front panel controls provide easy adjustment of source volumes and master volume
  • Rated Power Output: 60W
  • Speaker Outputs:  70V/100V/4Ω/8Ω/16Ω, RCA Line Out
  • Connectors: Mic1 - Balanced XLR with phantom power
  • Frequency Response: 60Hz-15kHz(+/-3dB)
  • S/N Ratio: Line ≥ 85dB, Mic ≥ 72dB
  • THD: Less than 0.5%
  • Protection: short-circuit, clip, overload and high temp protection
  • Power Consumption: 100W
  • Power Supply: 110-230VAC, 50-60Hz
  • Dimensions:  12.6" x 8.27" x 3.54" (320 x 210 x 90 mm)
  • Weight: 9.5 lbs. (4.3kg)
BrandRussound
ModelMIXAMP-60
Part Number247-1916
UPC612934853470
Weight12.8
Power Output (RMS @ 70V)51W to 100W
Weight Range< 10 lbs.
