  • Russound AW70V6mk2 6.5" Indoor/Outdoor Surface Mount Speaker 6 Ohm / 70V / 100V White Pair
NEW Russound AW70V6mk2 6.5" Indoor/Outdoor Surface Mount Speaker 6 Ohm / 70V / 100V White Pair
RussoundPart # 247-1914
Model: AW70V6mk2 WHITE
The Russound AW70V6MK2 70V/100V Surface‑Mount Speaker is a surface-mount speaker built for indoor or outdoor distributed audio systems, designed to meet the demands of both residential and commercial installations. It offers adjustable transformer taps for versatile use in 70 V / 100 V zones, or full-power low-impedance bypass. Its rugged mounting system supports one-handed installation and multi-orientation mounting.
  • 70 V / 100 V transformer with weatherproof tap settings and 6Ω bypass option
  • 6.5″ injection-molded polypropylene woofer with 1″ titanium dome tweeter
  • Rugged one-handed mounting bracket for vertical, horizontal, or pole mounting
  • Dual 1/4″-20 brass inserts for third-party mounting systems
  • Adjustable taps: 7.5, 15, 30, 60 W (70 V); 15, 30, 60 W (100 V)
  • Powder-coated aluminum grille for weather resistance
NEW $689.00
We'll send you an email when Russound AW70V6mk2 6.5" Indoor/Outdoor Surface Mount Speaker 6 Ohm / 70V / 100V White Pair is back in stock or available for preorder.
AW70V6mk2 6.5" Indoor/Outdoor Surface Mount Speaker 6 Ohm / 70V / 100V Pair
  • Description: 2-way Indoor/Outdoor Loudspeaker Pair
  • Woofer: 6.5” (16.51cm) Injection-Molded Polypropylene
  • Tweeter: 1” (2.54cm) Titanium Dome
  • Mounting Options: Bookshelf foot, pole, flat or corner surface
  • Dimensions: 13" x 8.75" x 8.25" (33.02 x 22.22 x 20.95 cm)
  • Wire Gauge: Up to 12ga AWG
  • Grille: Powder Coated Aluminum
  • Bracket: Aluminum
  • Bookshelf foot: Yes
  • Sensitivity: 87 dB
  • Frequency Response: (+/- 3dB): 55Hz-20kHz
  • Nominal Impedance: 6 ohm
  • Tap Settings: 70V: 7.5W, 15W, 30W, 60W | 100V: 15W, 30W, 60W | 6Ω
BrandRussound
ModelAW70V6mk2 WHITE
Part Number247-1914
UPC612934853883
Unit of MeasurePairs
Weight21.9
ColorWhite
Configuration2-way
Construction MaterialsHardshell / ABS Case
Input Rating6Ω|70V|100V
Mounting StyleSurface Mount
Woofer Diameter6.5"
Special FeaturesIndoor / Outdoor
