  • Dayton Audio DA650D Commercial Audio Amplifier 650W 70V/ 100V/ 4 Ohm Mixer - 4 Mic 2 Aux 1 Telephone input
Dayton AudioPart # 300-524
Model: DA650D
Experience unparalleled audio performance with the Dayton Audio DA650D commercial amplifier. With a staggering 650-watt power output, this amplifier promises clear and high-quality sound, making it ideal for large spaces and commercial setups. Its commercial-grade build ensures durability, while the 70V constant voltage design offers efficient power distribution. From multiple connectivity options to Bluetooth streaming and an FM radio tuner, the DA650D is a versatile powerhouse designed for professionals. Its rackmount design ensures it integrates seamlessly into any professional audio setup.
  • 70V Constant Voltage design efficiently powers multiple speakers over extended distances.
  • 650-Watt power output delivers clear sound, perfect for large spaces and commercial applications.
  • Commercial-grade build offers superior durability and consistency for continuous usage.
  • Four terminal block microphone/line level inputs and 2 RCA auxiliary inputs.
  • Stream music from various sources and curate company-specific playlists or tune into your favorite radio stations for a diverse audio experience.
  • EMC & Mute Triggers allows control over sound output for announcements or security alarms.
  • Rackmount design fits seamlessly into standard equipment racks for professional convenience.
Your Price: $849.98
MSRP: $1,104.99
Save $255.01 (23%)
We'll send you an email when Dayton Audio DA650D Commercial Audio Amplifier 650W 70V/ 100V/ 4 Ohm Mixer - 4 Mic 2 Aux 1 Telephone input is back in stock or available for preorder.
Order in the next 10 hr 38 min to ship today. Details
Dayton Audio DA650D 70V 650W Rackmount PA Mixer-Amplifier
The DA650D is a 70V, constant voltage commercial amplifier that can power multiple speakers over extended distances efficiently without the obstacles of impedance loading. This makes it an excellent choice for large venues or multi-room audio systems, where maintaining consistency in sound quality across vast expanses is key. For maximum compatibility, the DA650D can also support systems with a minimum impedance of 4 Ohms.
650-Watt Power Output
The Dayton Audio DA650D stands out with its impressive 650-watt power output. This ensures that even in expansive spaces, the sound remains clear and of high quality. It's especially beneficial for distributed audio systems or commercial venues where a robust audio signal is crucial.
Multiple Connectivity Options
Flexibility is at the core of the DA650D. With four terminal block microphone inputs that can switch to line level and 2 RCA auxiliary inputs, it caters to a diverse range of audio setups. This versatility is invaluable for professionals who often need to adapt to varying audio requirements.
FM, Bluetooth, USB & SD Card Reader
Despite its robust nature, the DA650D doesn't compromise on modern features. It offers Bluetooth streaming capabilities and comes equipped with both USB and SD card readers. This ensures you can play audio from multiple sources, tailoring playlists to match your company's ambiance.
The inclusion of an FM radio tuner adds a touch of versatility to the DA650D. Whether you want background music or to tune into a popular radio show, this feature ensures you have a variety of audio options at your fingertips.
Commercial Grade Rackmount Design
Constructed with commercial-grade materials, the DA650D promises durability and consistent performance. It's designed to withstand the demands of continuous operation, ensuring longevity and making it a valuable addition to any commercial audio setup. The DA650D's rackmount design ensures easy integration into standard equipment racks. This not only ensures a seamless fit into existing setups but also signifies its capability to handle the demands of a professional environment.
Maintain the perfect audio environment with the DA650D's EMC and mute triggers. These features allow you to mute other outputs for announcements or in case of security alarms, ensuring the audio setup aligns with the venue's requirements.
  • Power Output: 1300W @ 4ohms, 650W @ 8ohm
  • Inputs: 7 (4 Euroblock, 2 Stereo RCA, 1 Digital interface with USB, SD, BT, and FM)
  • Output: 1x Barrier Strip for 70V/4ohm load
  • Remote Control Battery: CR2025
  • Dimensions: 19 x 12.5 x 1.75
  • Weight: 10.58 lbs
ModelDA650D
Part Number300-524
UPC848791009600
Weight11.85
