  • Russound IC-830 IC Series 8" Premium Performance Speaker Pair
RussoundPart # 247-1906
Model: IC-830
The Russound IC-830 is an 8″ premium in-ceiling speaker that scales up the capabilities of Russound’s flagship line. It’s built for main listening rooms and features upgrades in size and materials to deliver stronger lows and clearer highs.
  • 8″ injection-molded polypropylene woofer with vapor-deposited titanium coating
  • 1″ pivoting titanium dome tweeter aims highs precisely toward the listening area
  • Tweeter level switch (±3 dB) allows high frequency adjustment based on room absorption
  • SwiftLock® tool-less mounting system speeds up secure installation
  • Pin-Cushion, EasyGrip™ tweeter bridge allows for simple, one-handed installations
  • Paintable edgeless grille offers a clean, décor-friendly finish
  • Magnetic grille attachment with strong neodymium magnets
Russound IC-820 IC Series 8" Enhanced Performance Speaker Pair
Price: $569.00Part # 247-1905
See all items in In-ceiling Speakers
Your Price: $799.00
Out of Stock
We'll send you an email when Russound IC-830 IC Series 8" Premium Performance Speaker Pair is back in stock or available for preorder.
Special Order Item Ships in 5-10 Days
The IC Series... A Family of Innovation
The IC Series is carefully designed, crafted, and tuned to deliver the most rewarding listening experience possible. This versatile range of speakers offers excellent options for any application, from budget-conscious setups to audiophile-grade systems. Whether installed in-wall or in-ceiling, they are ideal for multi-room audio, home theaters, primary listening, and more.
The New NanoPerf™ Grilles Are Incredibly Slim And Brilliantly White
Voice Matching Made Easy
The IC Series can be split into three subseries: the entry-level 10-Series, the high-fidelity 20-Series, and the premium 30-Series. Each series is designed to be acoustically matched with the rest of the series to make mixing and matching for each installation simple.
How Can You Improve On Installation? Like This...
Along with delivering a significant upgrade in sound quality, the new IC-Series speaker lineup was designed with installers in mind. By maintaining the same cut-out sizes as previous models and introducing an innovative installation method, these speakers are now among the easiest and most installer-friendly options available.
You'll never want to install speakers again any other way
Engage
To activate the new SwiftLock™ feature, simply place the speaker in the ceiling and press the blue buttons.
Instant Locking
The dog automatically rotates and clamps down, adjusting to the ceiling or wall thickness while locking securely in place for a stable installation.
Quick Release
If you ever need to remove the speaker, the process is quick and simple. Just press the SwiftLock dog inward and make a half-turn with a screwdriver to lock it back in place, ready to be reactivated with the push of a button.
Three dogs are faster than four
The entry-level 10-Series (IC-610 and IC-610T) models uphold Russound’s tradition with a custom 3-dog design that reduces screwdriver work by 25% when working from a ladder, while ensuring the speakers are securely mounted to the ceiling without gaps, bumps, or shadow lines.
Push the button and throw away your drill
Upgrading to the new 20-Series or 30-Series models will feel like a game changer. With a simple press of a button on each of the three mounting dogs, the speaker locks firmly into place... no screwdriver or drill required. Say goodbye to over-tightened or under-tightened dogs, and enjoy a fast, clean installation with dogs that are precisely adjusted and spring-tensioned to grip the ceiling securely every time.
IC-830 8" Premium Performance Speaker Pair
Left, Right, Center Stage For Bigger Areas
The IC-830 is a larger version of Russound’s flagship in-ceiling speaker, the IC-630, designed to deliver detailed highs and powerful, full-bodied lows. Built with premium materials—including a 1" pivoting titanium tweeter and an 8" injection-molded polypropylene cone with vapor-deposited titanium—the IC-830 provides stunning performance that continues to impress over years of use. It features a ±3dB tweeter adjustment switch, allowing you to fine-tune the sound based on your room’s acoustics. In bright, reflective spaces with hard surfaces, set the switch to -3dB to soften the highs; in rooms with heavy furnishings, thick carpeting, or curtains, use the +3dB setting to enhance high-frequency detail. The patented SwiftLock® by Swarm system enables fast, tool-free installation with a simple press of a button on each of the three mounting dogs.
  • Type: Two-way in-ceiling
  • Cutout Dimensions: 8.25" (20.96 cm) diameter*
  • Frequency Response: 45 Hz - 20 kHz
  • Impedance: 8 ohms
  • Magnet Structure: 11 oz (0.312 kg)
  • Mounting Depth: 4.22" (10.7 cm)
  • Overall Dimensions: 9.37" (23.8 cm) diameter
  • Recommended Power: 5 - 110 watts
  • Sensitivity: 90 dB @ 1w/1m
  • Tweeter: 1” / (25 mm) Pivoting Titanium
  • Woofer: 6.5” / (16.51 cm) IM Polypropylene cone with vapor deposited Titanium
BrandRussound
ModelIC-830
Part Number247-1906
UPC612934853593
Unit of MeasurePairs
Weight14
Configuration2-way
Woofer Diameter8"
Special FeaturesSwiveling Tweeter
