  • Russound IC-610 IC Series 6.5" All-Purpose Ceiling Speaker Pair
RussoundPart # 247-1900
Model: IC-610
The Russound IC-610 is a two-way in-ceiling loudspeaker designed for multi-room audio installations. It features a 6.5″ polypropylene woofer with an integrated one-piece baffle for added rigidity and improved bass. The IC-610 blends seamlessly into décor with its paintable edgeless grille and installs quickly with its EasyGrip™ mounting system.
  • Two-way in-ceiling design with 6.5″ polypropylene woofer
  • Pivoting 0.75″ silk tweeter for precise direction of highs
  • Integrated one-piece baffle/woofer basket for stronger bass performance
  • Pin-Cushion, EasyGrip™ tweeter bridge allows for simple, one-handed installations
  • Paintable edgeless grille blends seamlessly into any décor
  • Powerful neodymium grille magnets for secure attachment
  • Includes cut-out template for quick and accurate installation
Russound IC-620 IC Series 6.5" Enhanced Performance Speaker Pair
Price: $399.00Part # 247-1902
See all items in In-ceiling Speakers
Your Price: $229.00
Out of Stock
We'll send you an email when Russound IC-610 IC Series 6.5" All-Purpose Ceiling Speaker Pair is back in stock or available for preorder.
Special Order Item Ships in 5-10 Days
The IC Series... A Family of Innovation
The IC Series is carefully designed, crafted, and tuned to deliver the most rewarding listening experience possible. This versatile range of speakers offers excellent options for any application, from budget-conscious setups to audiophile-grade systems. Whether installed in-wall or in-ceiling, they are ideal for multi-room audio, home theaters, primary listening, and more.
The New NanoPerf™ Grilles Are Incredibly Slim And Brilliantly White
How Can You Improve On Installation? Like This...
Along with delivering a significant upgrade in sound quality, the new IC-Series speaker lineup was designed with installers in mind. By maintaining the same cut-out sizes as previous models and introducing an innovative installation method, these speakers are now among the easiest and most installer-friendly options available. The IC-610 and IC-610T models uphold Russound’s tradition with a custom 3-dog design that reduces screwdriver work by 25% when working from a ladder, while ensuring the speakers are securely mounted to the ceiling without gaps, bumps, or shadow lines.
IC-610 6.5" All-Purpose Ceiling Speaker Pair
Multi-room Listening Never Sounded So Good
The IC-610 is a versatile listening speaker designed with a one-piece integrated baffle and woofer basket for added rigidity and rich bass performance. An excellent choice for multi-room audio, the IC-610 includes advanced features rarely found at this price point, such as an inverted parabolic surround and a pivoting tweeter (up to 15°) that lets you precisely aim the crucial midrange and high-frequency sounds. You’ll be impressed by the performance these speakers deliver.
  • Type: Two-way in-ceiling
  • Cutout Dimensions: 8.25" (20.96 cm) diameter*
  • Frequency Response: 50 Hz - 20 kHz
  • Impedance: 8 ohms
  • Magnet Structure: 11 oz (0.312 kg)
  • Mounting Depth: 3.98" (10.1 cm)
  • Overall Dimensions: 9.37" (23.8 cm) diameter
  • Recommended Power: 5 - 90 watts
  • Sensitivity: 88 dB @ 1w/1m
  • Tweeter: 0.75" / (19 mm) Pivoting Silk
  • Woofer: 6.5” / (16.51 cm) Polypropylene cone
  • *Russound recommends cutting an 8.375” (21.27 cm) opening for ease of installation. A cut-out template is included in the packaging
BrandRussound
ModelIC-610
Part Number247-1900
UPC612934537141
Unit of MeasurePairs
Weight12
Woofer Diameter6.5"
