  • Russound IC-620T IC Series 6.5" Enhanced Single Point Stereo Speaker
RussoundPart # 247-1903
Model: IC-620T
The Russound IC-620T is a 6.5" single-point stereo in-ceiling speaker that reproduces both left and right channels from one unit. It’s made for spaces where deploying two separate speakers is impractical, yet you still want full stereo audio.
  • Ideal for primary listening areas of the home
  • Dual tweeters and dual voice-coil woofer to support stereo fidelity from one speaker
  • SwiftLock® tool-less mounting system speeds up secure installation
  • Pin-Cushion, EasyGrip™ tweeter bridge allows for simple, one-handed installations
  • Paintable edgeless grille offers a clean, décor-friendly finish
  • Magnetic grille attachment with strong neodymium magnets
  • Acoustically matched with the IC-620, IC-820, IC-820T and IW-620 for mixing and matching as needed
Russound IC-610T IC Series 6.5" Single Point Stereo Ceiling Speaker
Price: $218.00Part # 247-1901
See all items in In-ceiling Speakers
Your Price: $285.00
Out of Stock
We'll send you an email when Russound IC-620T IC Series 6.5" Enhanced Single Point Stereo Speaker is back in stock or available for preorder.
Special Order Item Ships in 5-10 Days
The IC Series... A Family of Innovation
The IC Series is carefully designed, crafted, and tuned to deliver the most rewarding listening experience possible. This versatile range of speakers offers excellent options for any application, from budget-conscious setups to audiophile-grade systems. Whether installed in-wall or in-ceiling, they are ideal for multi-room audio, home theaters, primary listening, and more.
The New NanoPerf™ Grilles Are Incredibly Slim And Brilliantly White
Voice Matching Made Easy
The IC Series can be split into three subseries: the entry-level 10-Series, the high-fidelity 20-Series, and the premium 30-Series. Each series is designed to be acoustically matched with the rest of the series to make mixing and matching for each installation simple.
How Can You Improve On Installation? Like This...
Along with delivering a significant upgrade in sound quality, the new IC-Series speaker lineup was designed with installers in mind. By maintaining the same cut-out sizes as previous models and introducing an innovative installation method, these speakers are now among the easiest and most installer-friendly options available.
You'll never want to install speakers again any other way
Engage
To activate the new SwiftLock™ feature, simply place the speaker in the ceiling and press the blue buttons.
Instant Locking
The dog automatically rotates and clamps down, adjusting to the ceiling or wall thickness while locking securely in place for a stable installation.
Quick Release
If you ever need to remove the speaker, the process is quick and simple. Just press the SwiftLock dog inward and make a half-turn with a screwdriver to lock it back in place, ready to be reactivated with the push of a button.
Three dogs are faster than four
The entry-level 10-Series (IC-610 and IC-610T) models uphold Russound’s tradition with a custom 3-dog design that reduces screwdriver work by 25% when working from a ladder, while ensuring the speakers are securely mounted to the ceiling without gaps, bumps, or shadow lines.
Push the button and throw away your drill
Upgrading to the new 20-Series or 30-Series models will feel like a game changer. With a simple press of a button on each of the three mounting dogs, the speaker locks firmly into place... no screwdriver or drill required. Say goodbye to over-tightened or under-tightened dogs, and enjoy a fast, clean installation with dogs that are precisely adjusted and spring-tensioned to grip the ceiling securely every time.
IC-620T 6.5" Enhanced Single Point Stereo Speaker
Enhanced Stereo Sound for Hard to Reach Places
The IC-620T is an upgraded single-point stereo speaker capable of reproducing both left and right channels from one unit, making it ideal for spaces where traditional stereo placement is not possible. Perfect for hallways, small rooms, or walk-in closets, it’s the go-to choice when separate left and right speakers can’t be installed. With dedicated inputs for both channels, dual tweeters, and a dual voice-coil woofer, the IC-620T is simple to install, easy to connect, and a great way to enhance sound quality without adding multiple speakers.
  • Type: Single Point Stereo
  • Cutout Dimensions: 8.375 (21.27 cm)
  • Frequency Response: 40 Hz - 20 kHz
  • Impedance: 8 ohms
  • Magnet Structure: 11 oz (0.312 kg)
  • Mounting Depth: 3.98" (10.1 cm)
  • Overall Dimensions: 9.37" (23.8 cm) diameter
  • Recommended Power: 5 - 100 watts
  • Sensitivity: 91 dB @ 1w/1m
  • Tweeter: Dual 0.75” / (19 mm) Fixed Silk
  • Woofer: 6.5” / (16.51 cm) Dual Voice-Coil Injection-Molded Polypropylene cone
BrandRussound
ModelIC-620T
Part Number247-1903
UPC612934853616
Weight12
Configuration2-way
Woofer Diameter6.5"
Special FeaturesStereo Dual Channel
