  • Pyle PSS6 6 Channel High Power Stereo Speaker Selector Switch
Pyle AudioPart # 310-2116
Model: PSS6
Pyle's PSS6 speaker selector allows up to 6 separate speaker pairs to be hooked up to your stereo system. Handles 100 watts per channel.
  • Controls up to six speaker pairs
  • Accepts speaker wires up to 14-gauge
  • One year manufacturer's warranty
Your Price: $42.77
MSRP: $70.99
Save $28.22 (40%)
We'll send you an email when Pyle PSS6 6 Channel High Power Stereo Speaker Selector Switch is back in stock or available for preorder.
Estimated back in stock 5/29/2026
The PSS6 speaker selector from Pyle allows up to 6 separate speaker pairs to be hooked up to your stereo system. Handles 100 watts per channel. The PSS6 is especially convenient if you have speaker sets in different rooms and want to turn them off independently. You can enjoy the convenience and flexibility of listening to multiple speaker pairs simultaneously.
For use with speakers that have a minimum impedance of 8 ohms. Please note this unit is not impedance matching and can present an impedance as low as 1.7 ohms to your receiver/amplifier depending on your configuration and use. Refer to the PDF manual in the resources section for an impedance chart.
Specifications: • Power handling: 50 watt RMS/ch, 100 watt max/ch • Frequency response: 20 Hz - 20 kHz • Channel separation: 80 dB • Dimensions: 9.05" W x 1.85" H x 5.90" D.
BrandPyle Audio
ModelPSS6
Part Number310-2116
UPC068888882125
Weight2.8
Inputs (Source)1
Speaker Outputs6
Volume ControlNo
