  • Pyle PSS4 4 Channel Stereo Speaker Selector Switch
Pyle AudioPart # 310-2114
Model: PSS4
Pyle's PPS4 speaker selector allows up to 4 separate speaker pairs to be hooked up to your stereo system. Handles 100 watts per channel.
  • Controls up to four speaker pairs
  • Accepts speaker wires up to 14-gauge
  • One year manufacturer's warranty
Your Price: $40.46
MSRP: $57.99
Save $17.53 (30%)
We'll send you an email when Pyle PSS4 4 Channel Stereo Speaker Selector Switch is back in stock or available for preorder.
The PSS4 speaker selector from Pyle allows up to 4 separate speaker pairs to be hooked up to your stereo system. Handles 100 watts per channel. The PSS4 is especially convenient if you have speaker sets in different rooms and want to turn them off independently. You can enjoy the convenience and flexibility of listening to multiple speaker pairs simultaneously.
For use with speakers that have a minimum impedance of 8 ohms. Please note this unit is not impedance matching and can present an impedance as low as 2.4 ohms to your receiver/amplifier depending on your configuration and use. Refer to the PDF manual in the resources section for an impedance chart.
Specifications: • Power handling: 50 watt RMS/ch, 100 watt max/ch • Frequency response: 20 Hz - 20 kHz • Channel separation: 80 dB • Dimensions: 7.48" W x 1.97" H x 4.72" D.
BrandPyle Audio
ModelPSS4
Part Number310-2114
UPC068888882118
Weight2.19
Inputs (Source)1
Speaker Outputs4
Speaker TypePassive / Unpowered
Volume ControlNo
