  • Pyle PDWRBT46BK 4" Outdoor Waterproof Bluetooth Speaker Pair Black
CLEARANCE Pyle PDWRBT46BK 4" Outdoor Waterproof Bluetooth Speaker Pair Black
Pyle AudioPart # 310-2463
Model: PDWRBT46BK
The Pyle PDWRBT46BK is a 4-inch, 2-way indoor/outdoor Bluetooth speaker system designed to deliver high-quality audio in any environment. Its waterproof construction and wireless capabilities make it ideal for use on boats, patios, decks, or poolside.
  • Bluetooth wireless streaming for convenient audio playback
  • Completely waterproof design for all-weather use
  • 1/2” high compliance polymer tweeter for crisp sound reproduction
  • ABS construction for long-lasting durability
  • Quick connect speaker terminals for hassle-free setup
  • Wall-mountable design for versatile placement options
  • Compact 4” 2-way speaker system to save space
CLEARANCE $72.00
Save $58.63 (45%)
3 In Stock
We'll send you an email when Pyle PDWRBT46BK 4" Outdoor Waterproof Bluetooth Speaker Pair Black is back in stock or available for preorder.
Order in the next 2 hr 57 min to ship today. Details
The PDWRBT46BK system boasts a maximum power output of 300 watts and an RMS power of 150 watts, giving ample volume and clarity for various applications. Its frequency response ranges from 60 Hz to 21 kHz, providing the full spectrum of sound. The package includes two speakers, mounting brackets, hardware, speaker cable, and a power adapter, offering a complete setup for immediate use.
Constructed with heavy-duty ABS material, the speakers are built to withstand harsh environmental conditions, offering longevity and reliable performance. The quick-connect speaker terminals and included mounting hardware make installation straightforward, whether you're setting up in a permanent location or planning to move the system as needed. With its blend of durability, high-quality sound, and modern connectivity, the Pyle PDWRBT46BK speaker system is an excellent choice for enhancing your audio experience both indoors and outdoors.
Technical Specifications
  • Construction Material: ABS
  • Subwoofers: 4” Aluminum Injection Cones
  • Tweeters: 1/2” High Compliance Polymer Tweeter
  • Max Power: 300 Watts
  • RMS Power: 150 Watts
  • Magnet: 30 Oz
  • Frequency Response: 60-21KHz
  • Impedance: 8 Ohm
  • Sensitivity: 90dB
  • Speaker Cable Length: 11.48 ft. / 3.5m
  • Power Output: DC12V, 2A (Power Adapter)
  • Product Dimensions (D x W x H): 4.72’’ x 5.51’’ x 8.11’’
  • Weight: 5.6 lbs. per speaker
  • Included: (2) Speakers, Mounting Brackets, Mounting Hardware, Speaker Cable, Power Adapter
BrandPyle Audio
ModelPDWRBT46BK
Part Number310-2463
UPC842893141664
Unit of MeasurePairs
Weight5.6
