  • Dayton Audio IO65XP Outdoor Bluetooth Speakers with Built-in 80W Amp, Enhanced Bass, Weather-Resistant, Wall-Mount – Wireless Garden, Garage, Pool, BBQ, Backyard Speakers (Pair, Black)
NEW Dayton Audio IO65XP Outdoor Bluetooth Speakers with Built-in 80W Amp, Enhanced Bass, Weather-Resistant, Wall-Mount – Wireless Garden, Garage, Pool, BBQ, Backyard Speakers (Pair, Black)
Dayton AudioPart # 310-040
Model: IO65XP Black
Upgrade your outdoor entertainment with the Dayton Audio IO65XP Bluetooth speaker system. Designed for patios, decks, and backyard spaces, these all-weather speakers deliver powerful, high-fidelity sound with the convenience of Bluetooth 5.3 wireless streaming. The built-in amplifier eliminates the need for an external receiver, while the passive bass radiator enhances low frequencies for a richer, more dynamic audio experience. Simply connect the speakers to wall power and link them together using the included cable. With easy installation and a rugged, weather-resistant design, this system is the perfect solution for bringing premium sound to any outdoor setting.
  • Bluetooth 5.3 Streaming: Enjoy seamless, high-quality wireless audio with enhanced range and stability.
  • All-Weather Durability: Rugged design resists rain, sun, and outdoor elements for year-round reliability.
  • Built-In 80-Watt Amplifier: No need for an external receiver—just connect to wall power and play.
  • Passive Bass Radiator: Boosts low frequencies for deeper, more dynamic sound.
  • Easy Installation: Quick and simple setup with included wall power and speaker-linking cable.
  • High-Fidelity Sound: Crisp, clear audio with powerful output, perfect for outdoor spaces.
  • Versatile Outdoor Use: Ideal for patios, decks, backyards, and poolside entertainment.
NEW $374.98
MSRP: $487.99
Save $113.01 (23%)
We'll send you an email when Dayton Audio IO65XP Outdoor Bluetooth Speakers with Built-in 80W Amp, Enhanced Bass, Weather-Resistant, Wall-Mount – Wireless Garden, Garage, Pool, BBQ, Backyard Speakers (Pair, Black) is back in stock or available for preorder.
Dayton Audio IO65XP Bluetooth 80 Watt Outdoor Installation Speaker Pair Black
Key Specs:
  • Design:  6-1/2" 2-Way Indoor Outdoor Speaker
  • Woofer: 6-1/2" Polypropylene Cone
  • Tweeter: 1" Soft Dome
  • Amplifier Power (RMS): 40 Watts Per Channel
  • Bluetooth Version: 5.3
  • Bluetooth Range: 30 feet (10m)
Built-In Bluetooth
The IO65XP is equipped with a built-in 2-channel amplifier and Bluetooth 5.3, eliminating the need to run wires through walls or ceilings—making installation fast, clean, and hassle-free. And because it’s designed for open-air use, the lack of walls or physical boundaries becomes a major advantage: Bluetooth range and stability are maximized, delivering strong, uninterrupted wireless audio performance up to 30 feet from the main speaker. Whether it's a patio, deck, or backyard, the IO65XP takes full advantage of open spaces to provide seamless connectivity and powerful sound.
Output & Low End
With 80 watts of built-in amplification and the convenience of Bluetooth connectivity, the IO65XP redefines outdoor audio by delivering powerful, high-quality sound with minimal setup. Designed for both performance and simplicity, this speaker is perfect for patios, decks, and open-air spaces where clean audio and easy installation are essential. At its core, the IO65XP features a 6.5" polypropylene woofer paired with a 1" soft-dome tweeter to ensure rich lows and crisp, detailed highs.
The IO65XP challenges the notion that outdoor speakers lack in low-end response. Without sacrificing durability, the IO65XP is able to produce extended bass by using a passive radiator. The passive radiator design allows the speaker to provide a surprisingly deep, tight bass response while keeping the enclosure small. The superb bass and natural, smooth high-end create an enjoyable listening experience no matter where installed, indoors and out.
For Use Indoors & Out
Flaunting an IP66 ABS enclosure, the IO65XP is perfect for outdoor use. The water-resistant build allows for the speaker to be used in outdoor applications, even in unfavorable environmental conditions. Rugged and durable build quality ensures a long life for years of enjoying great sounding audio.
Hook-Up Made Easy
Effortless setup in minutes! Simply connect the powered speaker’s output to the passive speaker’s input using the included 25 foot speaker wire, ensuring the connectors are securely tightened for a water-resistant seal. Then, plug the waterproof power supply into the DC input on the back of the powered speaker and connect it to mains power for reliable performance.
  • Design: 6-1/2" 2-Way Indoor Outdoor with Passive Radiator
  • Amplifier Power: 40 Watts Per Channel
  • Frequency Response: 45-20,000 Hz
  • Bluetooth Version:5.3
  • Included Speaker Cable length: 25 feet (7.5m)
  • Ingress Protection Rating: IP66
  • Dimensions: 11.25" W x 7.9" D x 7.7" H
  • Weight: 6.88 lbs. (Active), 6.75 lbs. (Passive)
ModelIO65XP Black
Part Number310-040
UPC848791011061
Unit of MeasurePairs
Weight13.63
ColorBlack
Configuration2-way
Mounting StyleSurface Mount
Woofer Diameter6.5"
Special FeaturesBluetooth
