  • Dayton Audio CSIO25 25' Speaker Extension Cable for IO65XP
Dayton AudioPart # 310-163
Model: CSIO25
The Dayton Audio CSIO25 is a 25-foot extension cable engineered for the IO65XP outdoor Bluetooth speaker system. It uses the same rugged, weather-resistant construction and waterproof screw-down connectors as the original cable included with the speakers. Ideal for increasing the distance between the powered and passive speakers or reaching more distant mounting locations in permanent outdoor installations.
  • 25 ft extension cable designed for use with the Dayton Audio IO65XP
  • Matches the original cable included with the IO65XP speaker pair
  • Waterproof screw-down connectors for secure, weather-resistant connections
  • Durable black 2-conductor cable with outdoor-rated jacket
  • Enables flexible speaker placement across larger outdoor areas
Your Price: $14.98
Save $5.01 (25%)
We'll send you an email when Dayton Audio CSIO25 25' Speaker Extension Cable for IO65XP is back in stock or available for preorder.
Engineered specifically for the Dayton Audio IO65XP outdoor Bluetooth speaker system, the CSIO25 extension cable provides an easy way to extend the distance between the powered and passive speakers when the standard length isn’t quite enough. This 25-foot cable features the same durable, weather-resistant construction and waterproof screw-down connectors as the original cable, ensuring reliable performance in any outdoor environment. Perfect for permanent installations, the CSIO25 allows you to reach more distant mounting locations or expand your setup while maintaining a secure, weather-sealed connection.
ModelCSIO25
Part Number310-163
UPC848791011085
Weight0.66
