  • PRV Audio WGP14-50PR White Matte 2" 45 x 45 Waveguide 4-Bolt
CLEARANCE PRV Audio WGP14-50PR White Matte 2" 45 x 45 Waveguide 4-Bolt
PRV AudioPart # 294-3032
Model: WGP14-50PR
The flangeless design of PRV Audio's WGP14-50PR white exponential horn gives your high output midrange and tweeter installation a clean look. With a 2" throat and 45° x 45° dispersion, this is perfect for applications where a controlled coverage pattern is needed and space is at a premium.
  • 5" of mounting depth and unique flangeless design for installation in tight spaces
  • 2" throat with standard 4-bolt mount is compatible with many popular compression drivers
  • Non-resonant reinforced ABS plastic construction
  • Minimum recommended frequency of 600 Hz
CLEARANCE $9.91
MSRP: $12.39
Save $2.48 (20%)
Quantity:Qty: 1-3 $9.91/ea
Quantity:Qty: 4-7 $9.41/ea
Quantity:Qty: 8+ $8.92/ea
17 In Stock
We'll send you an email when PRV Audio WGP14-50PR White Matte 2" 45 x 45 Waveguide 4-Bolt is back in stock or available for preorder.
PRV Audio's WGP14-50PR white exponential horn's flangeless design gives your high output midrange and tweeter install a sleek and clean look, even in tight spaces. A standard 4-bolt flange is compatible with most 2" compression drivers. This horn, constructed from non-resonant ABS plastic, is perfect for outdoor or automotive use. Acoustic loading is maintained down to 600 Hz.
Specifications:• Horn type: Exponential • Minimum frequency: 600 Hz • Nominal dispersion: 45° H x 45° V • Throat diameter: 2" • Mounting type: 4-bolt • Dimensions: 5.33" dia x 5" D • Cabinet cutout: 5.33" dia.
BrandPRV Audio
ModelWGP14-50PR
Part Number294-3032
UPC602938021685
Weight0.4
ConstructionABS
Entry / Throat Diameter2"
Mounting Type4-Bolt
