  • PRV Audio WGP12-25 SLIM BLACK 1” Screw-On Slim Waveguide
PRV AudioPart # 294-2845
Model: WGP12-25 SLIM BLACK
The PRV Audio WGP12-25 SLIM is a compact 1″ exit screw-on waveguide designed to maximize output from compatible compression drivers in limited space. Its shallow profile and optimized dispersion make it suitable for pro audio, outdoor, or automotive use where space is tight but performance is needed.
  • 1″ exit slim screw-on waveguide for compact installations
  • 2.95″ mounting depth with 5.20″ × 5.20″ faceplate takes up very little space
  • Compatible with standard 1-3/8″-18 TPI screw-on compression drivers
  • Constructed from non-resonant ABS plastic for outdoor or automotive use
  • 60° × 60° dispersion pattern for balanced coverage
  • Designed to deliver high output performance in very limited space
  • Recommended minimum crossover frequency of 800 Hz
Your Price: $12.91
Save $3.23 (20%)
We'll send you an email when PRV Audio WGP12-25 SLIM BLACK 1” Screw-On Slim Waveguide is back in stock or available for preorder.
Order in the next 4 hr 8 min to ship today. Details
PRV Audio WGP12-25 SLIM 1” Screw-On Slim Waveguide
The PRV Audio WGP12-25 SLIM compact screw-on waveguide is an exponential horn designed for applications where maximum output from a 1″ compression driver is essential. With a shallow 2.95″ depth and a 5.20″ x 5.20″ faceplate, it offers a compact solution for high-output sound systems.
A standard 1-3/8″-18 TPI screw-on mounting thread allows compatibility with all PRV 1″ exit screw-on compression drivers. Constructed from non-resonant ABS plastic, the WGP12-25 SLIM is well suited for outdoor and automotive installations. It maintains effective acoustic loading down to 800 Hz.
  • With a mounting depth of 3.35″ and a compact 5.20″ x 5.20″ faceplate, it occupies minimal mounting space and allows a compression driver to be installed between speakers
  • Designed to deliver high output from a very small footprint when paired with any PRV 1″ exit compression driver, with a 4.80″ diameter baffle cutout that simplifies front mounting models like the D290Py-S or D280Ti-S
  • 60° x 60° dispersion pattern suited for long-throw applications
  • Reinforced, non-resonant plastic construction with a patterned surface to reduce reflections and promote consistent sound coverage
  • Includes four mounting screws
  • Throat Diameter: 1” (25.4mm)
  • Mounting Type: Screw-on
  • Thread dimensions: 1-3/8"
  • Nominal Coverage:
          Horizontal 60°
          Vertical 60°
  • Flare type: Exponential
  • Material: Plastic (ABS)
  • Finish / Coating: Black
  • Dimensions (H x W x D): 5.20” (132mm) x 5.20” (132mm) x 3.35” (85mm)
  • Mount Depth: 2.95” (75mm)
  • Baffle Cutout Diameter: 4.85" (123.2mm)
  • Net Weight: 0.25lb (0.115kg)
BrandPRV Audio
ModelWGP12-25 SLIM BLACK
Part Number294-2845
UPC810075527469
Weight0.4
ConstructionABS
Construction MaterialsHardshell / ABS Case
Entry / Throat Diameter1"
Mounting Type1-3/8"-18 TPI
