  • PRV Audio RS8-SUBD4 RS Series 8" Subwoofer DVC 4x4 Ohm
CLEARANCE PRV Audio RS8-SUBD4 RS Series 8" Subwoofer DVC 4x4 Ohm
PRV AudioPart # 294-3581
Model: RS8-SUBD4
The PRV Audio RS8-SUBD4 is a 8" car subwoofer rated for 500 Watts RMS, designed to deliver impactful bass in tight spaces without sacrificing performance. It features a dual 4-ohm voice coil setup that lets you configure impedance flexibly for your system. Its compact build makes it ideal for pickup trucks, SUVs, or behind-seat installations.
  • Four layer high-temperature copper voice coil built for sustained 500 Watts RMS power handling
  • 14.5 mm Xmax with a high roll surround for deeper bass before distortion
  • Side forced cooling and vented back plate enable improved heat dissipation
  • Dual 4 Ohm coils allow wiring flexibility and easy impedance matching
  • Shallow mounting depth (4.96") makes installation possible in tight or compact enclosures
  • High temperature copper voice coil and beefy motor structure handle demanding power levels
CLEARANCE $139.91
MSRP: $174.89
Save $34.98 (20%)
1 In Stock
We'll send you an email when PRV Audio RS8-SUBD4 RS Series 8" Subwoofer DVC 4x4 Ohm is back in stock or available for preorder.
Order in the next 13 hr 34 min to ship today. Details
For 15 years, PRV Audio has designed and marketed professional live audio speakers, and is proud to launch the RS Series, which introduces new subwoofers, amplifiers, and car speakers built to deliver high-fidelity sound and performance specifically for the car audio market.
Compact yet powerful, the 8″ RS8-SUB car subwoofer delivers impactful bass. Engineered with performance in mind, it is an ideal solution for compact pickup trucks or any vehicle where you want to add a subwoofer without giving up trunk space.
  • Optimized for use in compact enclosures, ideal for under-seat or behind-seat truck boxes
  • 4-layer high-temperature copper voice coil capable of handling 500 watts RMS program power for high acoustic output
  • High roll U surround with 14.5 mm Xmax for low bass reproduction without distortion
  • Side-forced cooling system with vented back plate design for improved heat dissipation
  • Dual 4 Ohm design allows easy parallel connection of two subs to 1 ohm
This subwoofer is built with a heavy-duty magnet motor that boosts both output and low-end response, giving it the ability to handle more power while producing deeper, more impactful bass. The dual magnet structure provides an impressive 14.5 mm Xmax, offering excursion levels comparable to much larger subwoofers.
This powerful 8″ subwoofer can achieve 1.3″ peak-to-peak excursion before damage, enabling deep and impactful low frequency bass.
Recommended Amplifier configurations:
The LPF on amplifiers should be set between 80 – 100 Hz when using musical power up to 500 Watts RMS, Subsonic filters should be set according to music style, this will help to avoid subwoofer damage from excess excursion caused by ultra low frequencies.
Take your time and break them in! A brand-new sub is always a little stiff but after break-in, the subwoofer soft parts will stretch out! This means with less power you will create the same output with more extended low bass tones
Recommended Custom Enclosures: Inside measurements based with 3/4″ wood material.
Single Sub Sealed Enclosure 55 Hz Tunning
All sealed-enclosures should be filled to 50% of poly-fil.
VolumeBox SuggestionPort Size
0.54 ft³11" x 10" x 8.5"N/A
Single Sub Compact Ported Enclosure 50 Hz Tunning
0.78 ft³9" x 15" x 10"Slot Port 9”x1.25”
by 21″ Total Length
Dual Sub Recommended Ported Enclosure 42 Hz Tunning
1.85 ft³10" x 23" x 14"Slot Port 10”x2.5”
by 28″ Total Length
  • Nominal Diameter: 8″ (203 mm)
  • Nominal impedance: 4 + 4 Ohm
  • Nominal Power Handling: 250 Watts
  • Continuous Program Power (RMS): 500 Watts
  • Max Peak Power: 1000 Watts
  • Sensitivity 1.41V at 1m: 82 dB (Parallel VC)
  • Voice Coil Diameter: 2.4″ (61.1 mm)
  • Voice Coil Wire: Copper
  • Voice Coil Winding Depth: 33.0 mm
  • Former Material: Black Aluminum
  • Magnetic Gap Depth: 8.0 mm
  • Frame Material: Stamped Steel
  • Overall Diameter: 8.58″ (218 mm)
  • Front Mount Baffle Cutout: 7.40″ (188 mm)
  • Mounting Depth: 4.96″ (126 mm)
  • Overall Depth: 5.79″ (147 mm)
  • Net Weight: 17.78 lbs. (6.25 kg)
**Continuous Program Power (RMS) is the maximum power that the speaker can handle considering a regular musical program using our recommended filters, this power can be used to define the optimum amplifier power to avoid a clean signal without clipping or saturation.
BrandPRV Audio
ModelRS8-SUBD4
Part Number294-3581
UPC810075526233
Weight15.5
Nominal Diameter8"
Power Handling (RMS)500 Watts
Sensitivity82dB 2.83V/1m
Voice Coil Diameter2.4"
Resonant Frequency (Fs)53.4Hz
DC Resistance (Re)1.7Ω
Voice Coil Inductance (Le)1.24mH
Mechanical Q (Qms)8.13
Electromagnetic Q (Qes)0.82
Total Q (Qts)0.75
Compliance Equivalent Volume (Vas)0.13ft³
Mechanical Compliance of Suspension (Cms)0.06mm/N
BL Product (BL)9.55T·m
Diaphragm Mass Inc. Airload (Mms)132.2g
Maximum Linear Excursion (Xmax)14.5mm
Surface Area of Cone (Sd)201cm²
Voice Coil FormerAluminum
Overall Outside Diameter8.58"
Baffle Cutout Diameter7.40"
Depth4.96"
Sealed Volume0.253ft³
Sealed F361.93Hz
Vented Volume0.449ft³
Vented F330.1Hz
