  • PRV Audio RS65-CX RS Series 6.5" Coaxial Speaker Pair 4 Ohm
PRV AudioPart # 294-3584
Model: RS65-CX
The PRV Audio RS65-CX is a 6.5" 2-way coaxial car speaker pair engineered to replace OEM speakers cleanly with improved clarity and power handling. Each speaker delivers 80 Watts RMS (160 Watts program per pair) and spans a wide frequency range from 45 Hz to 20,000 Hz. With a standard frame size, molded basket, and included grille, it’s designed for relatively easy installation.
  • Soft silk dome 1" Neodymium tweeter with built-in crossover for smooth, detailed highs without harshness
  • 90 dB sensitivity helps achieve good volume with moderate amplifier or head unit power
  • Frequency response from 45 Hz gives deeper bass extension than many factory speakers
  • Compact mounting depth of about 2.40" (61 mm) lets it fit into many OEM door locations without modifications
Your Price: $69.91
Save $17.48 (20%)
We'll send you an email when PRV Audio RS65-CX RS Series 6.5" Coaxial Speaker Pair 4 Ohm is back in stock or available for preorder.
Introducing the RS65-CX premium 6.5” 2-way coaxial car speakers. Built for high performance, they are designed as the ideal choice for audiophiles who want to upgrade the sound quality of their car audio system.
The RS Series includes new subwoofers, amplifiers, and speakers that deliver high-fidelity sound and strong performance for everyday use, created specifically for the car audio market.
  • Small Profile, designed for easy installation with a standard frame size that fits many OEM door speaker locations, 4 Ohm impedance
  • 2-Way Coaxial, built-in soft dome tweeter with in-line capacitor blends smoothly with the woofer for detailed, rich sound
  • These 6.5″ coaxials feature a high quality silk dome tweeter and woofer, delivering accurate audio at 90 dB sensitivity, outperforming most stock car speakers
  • The RS65-CX 2-way coaxial is efficient and needs very little power to run, reaching high output easily with 160 watts RMS per pair, making it a great match for the compact QS400.4 2 Ohm
RS65-CX is built for simple installation with a standard 6.5″ frame size that matches many OEM door speaker locations.
While intended to be powered by an amplifier, this coaxial can also run from a factory or aftermarket radio, offering improved clarity and sound quality over OEM speakers.
The RS65-CX surrounds you with music throughout your vehicle. Upgrade today and experience the difference!
This 2-way car coaxial speaker is a great choice for anyone looking to step up from a basic factory upgrade. With a frequency range of 45 Hz to 20,000 Hz, it covers the full spectrum of sound.
Featuring a 6.5” woofer and a 1” neodymium tweeter with an integrated crossover, each driver handles its own frequency range. Everything connects through a single push-terminal, making installation simple without the need to adjust separate components.
Built to perform and able to handle 80 Watts RMS each, these car speakers are the most ideal OEM replacement.
If your car has 4x 6.5″ speakers or just 2x 6.5″ + 2x 6×9” you will only need one amplifier to power these speakers to reach high output levels.
The compact QS400.4 2 Ohm amplifier is able to power all 4 speakers, one per channel, getting them extremely loud with a small amount of power.
  • Nominal Diameter: 6.5″ (165 mm)
  • Nominal impedance: 4 Ohm
  • Continuous Program Power (RMS)**: 80 Watts
  • Max Peak Power***: 160 Watts
  • Sensitivity 2.00V at 1m: 90 dB
  • Frequency Response: 45 – 20,000 Hz
  • Voice Coil Diameter; 1.2″ (30 mm)
  • Voice Coil Wire: Copper
  • Voice Coil Winding Depth: 10.0 mm
  • Former Material: Kapton
  • Magnetic Gap Depth: 5.0 mm
  • Frame Material: Stamped Steel
  • Overall Diameter: 6.50” (165 mm)
  • Front Mount Baffle Cutout: 5.63″ (143 mm)
  • Mounting Depth: 2.40” (61 mm)
  • Overall Depth: 3.40” (86.4 mm) with grille
  • Net Weight: 2.45 lbs. (1.10 kg)
**Continuous Program Power (RMS) is the maximum power that the speaker can handle considering a regular musical program using our recommended filters, this power can be used to define the optimum amplifier power to avoid a clean signal without clipping or saturation.
BrandPRV Audio
ModelRS65-CX
Part Number294-3584
UPC810075526714
Unit of MeasurePairs
Weight6.6
Speaker Size6.5"
Speaker TypeCoaxial
Power Handling (RMS)80 Watts
