  • PRV Audio RS10-SUBD4 RS Series 10" Subwoofer DVC 4x4 Ohm
CLEARANCE PRV Audio RS10-SUBD4 RS Series 10" Subwoofer DVC 4x4 Ohm
PRV AudioPart # 294-3582
Model: RS10-SUBD4
The PRV Audio RS10-SUBD4 is a 10" car subwoofer rated for 1000 Watts RMS, designed to deliver impactful bass in tight spaces without sacrificing performance. It features a dual 4-ohm voice coil setup that lets you configure impedance flexibly for your system. Its compact build makes it ideal for pickup trucks, SUVs, or behind-seat installations.
  • Four layer high-temperature copper voice coil built for sustained 1000 Watts RMS power handling
  • 17.5 mm Xmax with a high roll surround for deeper bass before distortion
  • Side forced cooling and vented back plate enable improved heat dissipation
  • Dual 4 Ohm coils allow wiring flexibility and easy impedance matching
  • Shallow mounting depth (6.61") makes installation possible in tight or compact enclosures
We'll send you an email when PRV Audio RS10-SUBD4 RS Series 10" Subwoofer DVC 4x4 Ohm is back in stock or available for preorder.
For 15 years, PRV Audio has designed and marketed professional live audio speakers, and is proud to launch the RS Series, which introduces new subwoofers, amplifiers, and car speakers built to deliver high-fidelity sound and performance specifically for the car audio market.
This 10″ car subwoofer delivers bass you can feel like never before! The RS10-SUBD4 is ideal for adding low-end punch to your car system or filling your neighborhood with powerful sound.
Engineered to strike the right balance between cost and performance, this subwoofer maintains quality without compromise. It’s the perfect choice for daily builds where you want strong output with minimal electrical upgrades and efficient power use.
  • Bass powerhouse that delivers commanding low frequencies while requiring only minimal power
  • 4-layer high-temperature copper voice coil capable of handling 1000 watts RMS program power for high acoustic output
  • High roll U surround with 17.5 mm Xmax for low bass reproduction without distortion
  • Side-forced cooling system with vented back plate design for improved heat dissipation
  • Dual 4 Ohm design allows easy parallel connection of two subs to 1 ohm
This subwoofer is equipped with a robust magnet motor that boosts power and low-end response, enabling it to manage higher power while producing deeper, fuller bass.
Its dual magnet motor paired with a flexible high foam surround delivers an impressive 17.5 mm Xmax, offering extreme excursion for powerful output.
Add serious low-end to your system with this 10″ sub, capable of reaching 1.50″ peak-to-peak excursion before damage, delivering deep and impactful bass.
Recommended Amplifier configurations:
The LPF on amplifiers should be set between 60 – 90 Hz when using musical power up to 1000 Watts RMS, Subsonic filters should be set according to music style, this will help to avoid subwoofer damage from excess excursion caused by ultra low frequencies.
Take your time and break them in! A brand-new sub is always a little stiff but after break-in, the subwoofer soft parts will stretch out! This means with less power you will create the same output with more extended low bass tones
Recommended Custom Enclosures: Inside measurements based with 3/4″ wood material.
Single Sub Sealed Enclosure 52 Hz Tunning
All sealed-enclosures should be filled to 50% of poly-fil.
VolumeBox SuggestionPort Size
0.75 ft³11" x 13" x 9"N/A
Single Sub Compact Ported Enclosure 38 Hz Tunning
1.55 ft³11.5" x 16.75" x 14"Slot Port 11.5”x1.50”
by 26″ Total Length
Dual Sub Recommended Ported Enclosure 38 Hz Tunning
2.88 ft³11.5" x 31" x 14"Slot Port 11.5”x3”
by 28″ Total Length
  • Nominal Diameter: 10″ (254 mm)
  • Nominal impedance: 4 + 4 Ohm
  • Nominal Power Handling: 500 Watts
  • Continuous Program Power (RMS): 1000 Watts
  • Max Peak Power: 2000 Watts
  • Sensitivity 1.41V at 1m: 84 dB (Parallel VC)
  • Voice Coil Diameter: 2.6″ (65.5 mm)
  • Voice Coil Wire: Copper
  • Voice Coil Winding Depth: 40.0 mm
  • Former Material: Black Aluminum
  • Magnetic Gap Depth: 10.0 mm
  • Frame Material: Stamped Steel
  • Overall Diameter: 10.37″ (263.5 mm)
  • Front Mount Baffle Cutout: 9.13″ (232 mm)
  • Mounting Depth: 6.61″ (168 mm)
  • Overall Depth: 7.16″ (182 mm)
  • Net Weight: 21.27 lbs. (9.65 kg)
**Continuous Program Power (RMS) is the maximum power that the speaker can handle considering a regular musical program using our recommended filters, this power can be used to define the optimum amplifier power to avoid a clean signal without clipping or saturation.
BrandPRV Audio
ModelRS10-SUBD4
Part Number294-3582
UPC810075526332
Weight24.2
Nominal Diameter10"
Sensitivity84dB 2.83V/1m
Voice Coil Diameter2.6"
Resonant Frequency (Fs)48.5Hz
DC Resistance (Re)1.7Ω
Voice Coil Inductance (Le)1.54mH
Mechanical Q (Qms)10
Electromagnetic Q (Qes)0.74
Total Q (Qts)0.69
Compliance Equivalent Volume (Vas)0.29ft³
Mechanical Compliance of Suspension (Cms)0.054mm/N
BL Product (BL)11.76T·m
Diaphragm Mass Inc. Airload (Mms)198.7g
Maximum Linear Excursion (Xmax)17.5mm
Surface Area of Cone (Sd)330cm²
Voice Coil FormerAluminum
Overall Outside Diameter10.37"
Baffle Cutout Diameter9.13"
Depth6.61"
Sealed Volume0.503ft³
Sealed F360.04Hz
Vented Volume0.838ft³
Vented F329.26Hz
