  • PRV Audio D4400Ph Phenolic Compression Driver 8 Ohm 4-Bolt
CLEARANCE PRV Audio D4400Ph Phenolic Compression Driver 8 Ohm 4-Bolt
PRV AudioPart # 294-2795
Model: D4400Ph
PRV Audio's D4400Ph 2" midrange compression driver is an ideal combination of high efficiency and natural response. The 4" phenolic diaphragm produces a frequency response of 700 to 7,000 Hz making this driver perfect delivering low distortion vocal reproduction.
  • This 109 dB efficient driver is perfect for the highest output audio systems
  • Large 4" voice coil can handle up to 400 watts RMS
  • Phenolic diaphragm delivers natural response throughout the vocal range
  • Ideal midrange for use in large, high output multi-way systems
We'll send you an email when PRV Audio D4400Ph Phenolic Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
The D4400Ph 2" exit phenolic mid-range compression driver is the latest improved version of PRV Audio's D4260Ph. The nearly indestructible phenolic diaphragm structure, designed for vocal reproduction, allows midrange reproduction from 700 to 7,000 Hz. PRV designed this driver for midrange support in multi-way PA's, stage monitors, home theater, and high SPL car audio systems.
Specifications: • Power handling: 200 watts RMS with recommended crossover of 700 Hz, 12 dB/octave slope • VCdia: 4" • Impedance: 8 ohms • Frequency response: 500-7,000 Hz • SPL: 109 dB 2.83V/1m • Dimensions: 8.66" diameter x 3.03" depth • Net weight: 22.14 lbs. • Mounting: 4 x M6 bolt holes on a 4" diameter (hardware included) • Replacement diaphragm available (please see Related Items).
BrandPRV Audio
ModelD4400Ph
Part Number294-2795
UPC602938021135
Weight22
Diaphragm MaterialPhenolic
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)200 Watts
